Thread: annotation scale list
    2007-09
    36
    Default annotation scale list
    I thouht i saw a thread similiar to this but I can't find it now so if this is a repost just let me know.
    My Annotation Scale list is populated by a large amount of scales that are listed like the following:
    1/2" = 1'-0"_XREF_XREF_XREF_XREF_XREF_XREF
    I have no clue how many are actually listed its a lot though.
    There are no x-ref's in the drawing.
    I've tried the scale list edit command but end up with an "UNHANDLED EXCEPTION" error.
    Any help would be very appreciated, Thanks.
    2000-01
    Seattle WA USA
    5,859
    Default Re: annotation scale list
    Please download the Scale List Cleanup Utility. See here.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2007-09
    36
    Thank you,
    I was looking for something like that.
    2007-07
    Madison, WI
    185
    Quote Originally Posted by RobertB View Post
    You can also run the scale list edit command in the command bar mode as follows <-scalelistedit> the "-" is important. Then just follow the command prompts. If you want some fun press ? then eneter. it will tell you how many scales are in the drawing. I recieved a drawing from a client with ove 21,000.
    Then press r then enter to reset to the default 32 (or 33 whatever it is) scales.
  1. Replies: 10
    Last Post: 2022-08-25, 10:06 PM
  2. Annotation Scale list keeps propagating the whole list
    By jacep in forum AutoCAD Annotation
    Last Post: 2007-12-13, 06:24 PM
  3. Replies: 6
    Last Post: 2007-05-24, 08:44 PM
  4. AutoCAD 2008 Delete scale from Annotation Scale list
    By cgerhardt in forum VBA/COM Interop
    Last Post: 2007-04-25, 02:21 PM
  5. Accessing the annotation scale list in AutoCAD 2008
    Last Post: 2007-04-24, 08:28 PM
