Is it possible to change the metadata (Sheet Properties) of a DWF using Design Review or DWG toolkit?
I am exporting from Revit, and get metadata fields such as "Current Revision" and "Checked by" on the DWF sheet properties. I would like to be able to change these to tie in with our document management system in a similar way to changing block attributes as we can do with DWG files.
Is this possible?
