Thread: SIM Sections don't show on plans
    AUGI Addict DaveP's Avatar
    2002-12
    St Paul, MN
    1,569
    Default SIM Sections don't show on plans
    Can someone confirm if this is by design?
    If I create a Section - say from an Elevation - it shows on the Plan. If I then create another Section and Reference the first one, the second shows SIM as it should, but the second Section doesn't show up anywhere except in the View I drew it.
    Is there any way to get a SIM Section to show up in other Views?
    2007-07
    Madison, WI
    185
    Default Re: SIM Sections don't show on plans
    I can't see a way to do it. When you check the box "reference other view" they behave like an annotation (i.e. a dimension) If you want to see them in other floor plans you could select them>copy to clip board> Paste Aligned> Select views by name (another clue there. you can't select "select levels by name" with these either.) I thought maybe you could use this to paste them to elevations as well, but you only get views that are on a parallel plane.
  1. 2013: Joist framing between sections and plans
    By jessrspeas345667 in forum Revit Structure - General
    Last Post: 2013-12-04, 06:58 PM
  2. Local sections in formwork plans
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2012-11-03, 11:09 AM
  3. 3D sections of each level with Floor plans
    By rtaube in forum Revit Architecture - General
    Last Post: 2012-09-28, 09:24 PM
  4. I wish there was a way to define different hatch pattern behavior between plans and sections
    Last Post: 2008-06-17, 07:20 PM
  5. Hatch Alignment: Sections and Plans
    By mccurdyks in forum Revit Architecture - General
    Last Post: 2007-12-05, 05:44 PM
