Thread: Room.Name is really Room Name + Room Number
    Default Room.Name is really Room Name + Room Number
    Hello All,
    I'm wondering why when I reference a room object in my Revit project and query the Room.Name property the Room name and room number are returned in the same string. For example
    In my project I have a room whose Name value = 'OFFICE' and whose Number value = '101'
    Autodesk.Revit.Elements.Room rm
    rm.Name
    returns:
    OFFICE 101
    Each time I Get() the .Name value I have to remove the Room Number. The Set() function, however, works as expected.
    One of the API examples (\Revit 2009 SDK\Samples\RoomSchedule\) seems to have run afoul of this anomoly because when you look at the included sample XLS file the room number is appended several times. See the 'Room Name' column in the file 'RoomSchedule.xls' to see what I mean.
    It's easy to write a function to parse the room name, but still the current return value seems like odd behavior to me.
    Trevor
    2003-11
    New Zealand
    1,116
    Default Re: Room.Name is really Room Name + Room Number
    This is standard behaviour (as of RAC2008? API). To get the name and number independently get the BuiltInParameter's ROOM_NAME and ROOM_NUMBER.
    Cheers,
    Guy
    Thanks for the reply! I looked into the RvtMgdDbg project and also found the answer there.
    Trevor
    2008-07
    18
    One easy way is to use the C# String split method.
    Obtain the room name and room number. Find the string room number in the room name.
    Then trim the room name after getting the index of the room number.
    String fullname = _room.Name;
    String justname = fullname.Substring(0, fullname.IndexOf(_room.Number));
    Hope this helps.
    -KKLSARA
  1. 2015: Using Room Separtors and Room Schedule Showing Area Not Placed
    By Thayana in forum Revit Architecture - General
    Last Post: 2014-11-12, 07:38 AM
  2. Create Room Tag Room Number
    By imiller.203205 in forum Revit Architecture - General
    Last Post: 2010-08-04, 06:35 PM
  3. Replies: 2
    Last Post: 2008-11-03, 02:24 PM
  4. room number will not show up on room tag
    By jordannw in forum Revit Architecture - General
    Last Post: 2007-12-28, 05:41 PM
  5. a room tag that will show "room length x room width"
    By bayejid_bd in forum Revit Architecture - General
    Last Post: 2006-02-06, 08:48 PM
