Results 1 to 8 of 8
Thread: added file for reference in vault how to remove
    2005-07
    98
    Default added file for reference in vault how to remove
    i accidentally referenced the wrong surface file when i was check in my drawing, how do i remove the reference
    2008-03
    Laurel, MD
    509
    Default Re: added file for reference in vault how to remove
    remove the reference or the file?
    2005-07
    98
    remove the reference listing from the prospector tab of the tool space
    2008-03
    Laurel, MD
    509
    If you haven't actually used it for anything you should just be able to right click and delete it.
    2005-07
    98
    i don't even have that option
    i am talking about references listed under projects
    please see attached image
    2008-03
    Laurel, MD
    509
    You can erase the surface in the drawing. I thought you wanted to get rid of a surface already referenced to your drawing.
    2005-07
    98
    yes i can erase the surface form my drawing but how do i remove it from the tool space reference list.
    2007-06
    271
    When Vault can no longer find the surface, it will stop referencing the surface in your tool space reference list. Remove the original drawing, or delete the surface from that drawing (if for whatever reason you have a surface in a file with more than just the surface) as was mentioned earlier.
  1. Replies: 0
    Last Post: 2011-12-09, 02:57 PM
  2. Remove a Valve (IPart) from a custom Vault library
    By prowland in forum Vault - General
    Last Post: 2007-03-21, 06:35 AM
  3. Reference Option Added to MOCORO Command
    Last Post: 2007-01-29, 01:44 PM
  4. remove all reference locks
    By J-G in forum Revit Architecture - Wish List
    Last Post: 2004-03-02, 05:01 PM
