Thread: Default Feature Line Style
    2005-05
    IL
    103
    Default Default Feature Line Style
    Ok, I think I did my best to search for this answer and have come up with nothing so I'm gonna throw this out there......
    First off, I'm using C3D2008 (Service Pack 2)
    My firm has styles set up for feature lines based on if they are existing or proposed, etc and usually we'll go through and add any existing feature lines to a surface and then everything past that point will be proposed ones. Going to Grading->Draw Feature Line brings up the Create Feature Lines dialog box where you can specify what style to use and more. I found that in the Toolspace/Settings tab you can set some of these default settings for example set it to always use one particular style. This is helpful when we are drawing a lot of one style of feature lines but what I'm looking for is a way to control those default settings with a command or custom button.
    I'd like one button or command (e.g. "EX3D") that will set all the feature line command settings for our existing feature line style, etc. And of course another one for proposed, but I don't know how to control those settings with LISP or whatever would be needed. Any help or guidance would be appreciated. Maybe those settings can't be touched except doing it manually?
    Thanks again!
    2003-12
    43
    Default Re: Default Feature Line Style
    Since feature lines are created using a seperate application with in C3D you really can not specify which layer etc... it will go on except when that application is called with the drawfeatureline command. The way around this is to create a style that uses the byblock on everything and this way you can change the layer as you would a layer to an autocad object by selecting it and changing the layer it resides on. This also makes the need for several feature line styles not really needed.
  1. saving feature line style...
    By tpluie318707 in forum AutoCAD Map 3D - General
    Last Post: 2012-08-03, 10:49 PM
  2. AEC - default style - default layer - strange lines
    By chopsuey in forum ACA General
    Last Post: 2011-08-20, 01:21 AM
  3. feature line/surface style
    By oneill.tracy in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2009-04-09, 07:52 PM
  4. Unable to change Feature line, Line style
    By m.vanitallie in forum AutoCAD Civil 3D - Grading
    Last Post: 2008-03-20, 01:46 PM
  5. Custom Line Style Manager to Simplify Line Style Creation
    Last Post: 2008-01-09, 09:21 PM
