Results 1 to 10 of 13
Thread: Place Light Switches in Plan
    I could stop if I wanted to sschwartz85916's Avatar
    2005-04
    Oakland County, Michigan
    424
    Default Place Light Switches in Plan
    The ability to place light switches in the lighting plan view. Unless I am doing it wrong, (which is entirely possible) I constantly have to switch in between power and lighting views to first place the switches, then to assign the circuiting.
    Reflected ceiling plans are fine for architects, but we also have under cabinet lighting, wall mount lighting, etc. along with switches, etc...
    2008-06
    Adelaide, South Australia
    279
    Default Re: Place Light Switches in Plan
    Try changing the bottom view depth to 1100mm or just below whatever your switch mounting height is over there in imperial land.
    All you need to do after that is hide the unwanted elements that you end up seeing from that such as any receptacles/outlets that are mounted quite high, or panel/distribution boards.
    May work.
    I used this method on a test project trying to make the model functional yet looking roughly like our old ACAD drawings. See attached.
    You should be able to work out which one is the light switch and which ones are GPOs. (Australian standards, you'll work them out...)
    2000-01
    Seattle WA USA
    5,859
    Quote Originally Posted by sschwartz View Post
    The lighting plan should not be a reflected ceiling type view. RClgs are fine for coordination, but useless for the actual plans.
    R. Robert Bell
    Design Technology Manager
    Stantec
    2015-11
    Saint Louis, MO
    486
    2
    i actually use a ceiling plan for my lighting sheets, with view range from current floor up to next level (cut plane at floor), and turn off electrical fixtures,etc. (hide receptacles and voice/data device categories). then my power/systems sheets are floor plan views of the same model with view range from level above down to current level floor (cut plane at level above), with lighting fixtures and lighting devices turned off. each view has it's own tags, i think it works really well. i've attached a pdf of each from a current project. let me know if you need more specifics on the view ranges, that's possibly what's keeping you from placing switches in your lighting views.
    2000-01
    Seattle WA USA
    5,859
    Quote Originally Posted by mhartmann View Post
    i actually use a ceiling plan for my lighting sheets, with view range from current floor up to next level (cut plane at floor)...
    That does look pretty good.
    R. Robert Bell
    Stantec
    2008-06
    279
    Exactly how I do it. Although I just figured out how you "international" folk show which switch controls which set of lights. Never seen the letters next to the switch and the light before. We show ours slightly differently... Wires to lights indicate switching group for one.
    Revit MEP Moderator mjdanowski's Avatar
    2007-03
    890
    I do the same.
    To make things a bit easier however, I will just put power and lighting on different worksets. This way I can create the exact plan I want without having to play with V/G as much. It also makes it easier to segment bigger models.
    Matthew Danowski, PE, LEED AP BD+C
    Project Electrical Engineer
    Baltimore, MD
    2005-04
    424
    Quote Originally Posted by mjdanowski View Post
    I do the same.
    Interesting... I will have to try all of your helpful suggestions. Thanks, guys! (and/or gurls)
    All AUGI, all the time mwiggins121466's Avatar
    2006-09
    576
    I do the same.
    Ditto - We use different worksets by floor and by system - power, lighting, and misc systems.
    Margaret Wiggins
    Revit MEP 2006 and Greater
    Electrical Designer
    Detroit, Michigan
    wigginsm@yahoo.com
    2000-01
    Seattle WA USA
    5,859
    Please note that I've moved this thread out of the Wishlist forum, since there appears to be no valid wishing going on. (Well, maybe we are all wishing for better quality of life, but I digress.)
    R. Robert Bell
    Stantec
  1. Ø symbol when I try to place a light fixture
    By chrisl.224505 in forum Revit MEP - General
    Last Post: 2009-08-05, 03:35 AM
  2. How to place light fixtures with no ceiling
    By notoriousdw in forum Revit MEP - General
    Last Post: 2009-07-29, 07:49 PM
  3. How to show Light Switches on RCP
    By mr6jam in forum Revit Architecture - General
    Last Post: 2009-06-29, 01:58 PM
  4. Light Switches Help
    By bzig12 in forum Revit MEP - General
    Last Post: 2009-06-11, 11:19 PM
  5. Place light poles along an Arc
    By gabbagabba84 in forum AutoCAD General
    Last Post: 2006-12-06, 07:32 PM
