Thread: Very Basic Idea - Elevation Reference
    2001-08
    Dacula
    226
    Default Very Basic Idea - Elevation Reference
    I can't believe that Revit handles elevation references this way. Maybe I'm missing something even more fundamental....
    If I create an interior elevation in a CALLOUT of a floor plan that is on sheet A4.1, and place the elevation view on sheet A4.10, the view title references back to sheet A1.0.
    What gives here?
    TC
    AUGI Addict Andre Carvalho's Avatar
    2006-06
    Toronto, ON
    2,386
    Default Re: Very Basic Idea - Elevation Reference
    I think if you turn off the elevation in the view A1.0 (and any other view it is showing) under visibility/graphics, Revit will then reference the elevation to A4.1
    Andre Carvalho
    2006-06
    Toronto, ON
    2,386
    Just to add to my post above, you don't have to turn off all elevation tags on that view. Just select the interior elevation tag on that view and use EH to hide it.
    Also, remove the view A1.0 from the sheet (so Revit will take the reference from the view A4.1)and then add the view A1.0 to the sheet again.
    I hope it helps,
    Andre Carvalho
    2001-08
    Dacula
    226
    Andre;
    Your first suggestion works!
    I found out that hiding only one elevation marker does not cause the view title to reference correctly.
    I didn't try your other suggestion of removing the view and replacing it. Hopefully, I'll never need it.
    Thanks, you have restored my faith in Revit!!
    TC
    2006-06
    Toronto, ON
    2,386
    Quote Originally Posted by captainbunsaver View Post
    Andre;
    TC
    The second suggestion is useful when you want to keep other elevation marks on the same view. The first suggestion will turn off all the elevation marks because you are unchecking "Elevations" under visibility/graphics overrides. Unfortunately Revit doesn't have a an option to turn off only interior elevation... It is all or nothing.
    That said, if you want to keep other elevations tags and just hide one and still have your sheet to be referenced right, you have to follow the second suggestion.
    Andre Carvalho
  1. Elevation Tag - Level Reference?
    By cek in forum Revit Architecture - General
    Last Post: 2008-10-20, 12:44 AM
  2. Elevation Tag - Level Reference?
    Last Post: 2008-10-16, 06:01 PM
  3. Elevation Tag - Reference and live
    By tonyisenhoff in forum Revit Architecture - General
    Last Post: 2006-08-04, 05:50 PM
  4. Contour label--choose reference elevation
    By christo4robin in forum Revit Architecture - Wish List
    Last Post: 2005-02-28, 06:16 PM
  5. Reference another elevation view in 6.1
    By Paul Monsef in forum Revit Architecture - General
    Last Post: 2004-03-19, 11:08 PM
