Shouldn't the Inside Gaps and Outside Gaps be controlled in one location only? Isn't the gap option controlled in the "Mechanical Settings"? Well, on some projects it works, on others it doesn't.....it seems to be a BUG!!!!!
Is iT? Has anyone come across this?
What's weird is that even when they are set to be more than 1/8" (I even tried 1/2"), pipes and ducts don't show Gaps....but if I select 1 of the ducts, or pipes...then the gap is evident....but the moment I de-select, the gap disappears....and when it plots...it's also not present....
Is it a bug? or is there a secret 'thang that will make it magically work?
Seriously, it is frustrating....
