Thread: Slow selection of entities.
    2003-08
    16
    Default Slow selection of entities.
    I am currently using full AutoCAD 2004, I work in Architecture so the use of X refs are a must. The company has recently switched to Windows XP Professional.
    Since this change, if there are X refs attached/overlayed in a model, selection of entities has become very slow and annoying, to a point where I have literally walked out of the building to calm down. In paperspace...its even slower.
    On the other hand, AutoCAD is not slow when no X refs have been attached/overlayed.
    Has anybody else encountered this problem or is there an answer through AutoCAD, or do I wait for our IT department to find a solution.
    13,656
    Default Re: Slow selection of entities.
    Hi
    I honestly don't think this is the answer, but never the less take a look at the following thread -
    Delay in selecting objects in 2004
    For what it's worth have you applied Service Pack 1a to AutoCAD 2004 -
    AutoCAD® 2004 Service Pack 1a
    Have you checked your Graphic Card Driver is up to date?
    Have a good one, Mike
    Member dhurd's Avatar
    2004-01
    14
    Try sending the Xrefs to the "back of the drawing". Tools > Display Order > Send to Back and pick the xrefs. After that lock the Xref layer and they won't accidently get picked and brought to the "front".
  1. Replies: 20
    Last Post: 2015-03-16, 10:59 PM
  2. Adding code generated entities to a selection set
    By lambwill in forum Dot Net API
    Last Post: 2010-08-19, 05:51 AM
  3. Create a Selection Set of Entities as They are Created
    Last Post: 2008-10-12, 06:37 PM
  4. Replies: 1
    Last Post: 2007-03-08, 01:12 PM
  5. Slow Selection
    By chadwickt in forum AutoCAD General
    Last Post: 2005-04-08, 02:16 PM
