I was finally able to extract/update block attributes based on their handles. I'm trying now with text handles but I'm only able to extract to excel not the reverse.... stuck there. Can someone help on how to dig into the acadentity ?
Regards!
Regards!
I may try to help you if you post your code and dwg & xls files sample toghether with a better explanation of your aim.
bye
Hi Roby, Im trying to use with Autocad 2013 and I see the same error, I can extract file numbers but not attributes. Did you solved it?
This is a very handy tool. Thanks for the code.
Although my problem is that i have multiple instances of a certain block in multiple layouts but the code just returns attributes from the one that was added firstly to the layout.
Can someone help me with this?
