Thread: Copy/Paste Object Data
    2004-05
    24
    Default Copy/Paste Object Data
    It would be nice be able to copy the values of the object data of one object and paste it on to a new object. If you have 20 fields of object data, it is a nuisance to retype the same information. Thanks, TC
    2001-05
    Austin, TX USA
    2,201
    Default Re: Copy/Paste Object Data
    Check out my post about copy_od.
    Matchprop command in Autodesk MAP
    I do think this routine needs to be added to the map tool set. Instead of hiding it.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    2004-05
    24
    Cool. Considering the LISP has a copyright from 1998, it will work on all versions of MAP.
    2004-06
    123
    Works good and I had a list customized to attach closest text as OD with line on separate layer to show which text went where.
    Jim
  1. Copy an paste Autocad drawing oBject by VBA
    By grobnik in forum VBA/COM Interop
    Last Post: 2019-07-30, 05:28 AM
  2. Copy OBJECT DATA From Those are Overlaped
    By srinivasarajug in forum AutoLISP
    Last Post: 2014-08-05, 09:55 PM
  3. Right-click copy, paste, paste aligned
    By IanR in forum Revit Architecture - Wish List
    Last Post: 2008-07-04, 11:39 AM
  4. Copy / Paste object coordinates into text
    By IanR in forum AutoCAD Wish List
    Last Post: 2006-11-06, 09:32 PM
  5. Replies: 2
    Last Post: 2006-06-09, 04:39 PM
