saeborne
For overlapping areas, I've had to create different area plans. For example, to do BOMA calculations, you need to establish your gross building area, then subtract Major Vertical Penetrations.
As you know, If I lay out both areas on the same plan, then revit will automatically subtract one from the other. Mathematically, it works, but I need to produce that standard BOMA spreadsheet that our developers are used to seeing.
So how do I manage two different areas, that don't subtract when they overlap? I create a new Area Scheme.
In the Room and Area Tab, click on "Settings..."
Click on the "Area Schemes" tab.
In my example, I would create a "Gross Building Area" scheme, and a "Major Vertical Penetrations" scheme.
Now this will create two different types of area plans. But at least the areas can overlap.
For your situation, perhaps you could use the property line tool to highlight the lot area. The area within the property line will not change, regardless of what areas you create?
