Results 1 to 10 of 13
Thread: linking schedules with type elevation views
    2008-05
    Honolulu
    334
    Default linking schedules with type elevation views
    not sure how this is really done but...
    after inserting views by means of legend how can the title be linked to the "type" or "family" in the schedule..
    currently I am manually typing in the "type" in just the comment column...easy to error..
    got to be a better way...
    ray
    AUGI Addict luigi's Avatar
    2015-11
    Royal oak, Michigan
    1,513
    Default Re: linking schedules with type elevation views
    Sorry Ray, have a hard time understanding what you are trying to do...can you add some images possibly as well?
    Quote Originally Posted by ray salmon View Post
    ray
    2008-05
    Honolulu
    334
    basically in the scheduals it seems to be conventional to have one column as "type" refering to type of window (slider for example) then show an elevation view of the window (or door). there may only 3 types of windows but many shown on the plan..
    how is the schedual linked to the title of these elevation views of window and door types.... "families" in Revit seem to what "types" is conventioually..
    anyway if Revit is linked data there should be a way...
    ray
    2015-11
    Royal oak, Michigan
    1,513
    Are you talking about using legends when you are refering to "show an elevation view of the window (or door)?
    If legend, there is no way to tag that information...but in another view where you can use a tag..you can tag that information...
    But I might have misunderstood what you are trying to achieve......at least I am trying
    ray
    2008-05
    Honolulu
    334
    in you drawing sheet where are getting the elevation view of the doors from
    are you droping them in from the families menu??
    the "types" in the attachment are not linked to the schedual
    i had to keyboard all that in....
    just looking for a "wow" way to this....
    r
    2005-07
    3,250
    If we werea able to place Tags in legends, then you'd have your solution....schedule the Type Mark and tag the legend element with a tag that shows the Type Mark. Now they would be coordinated. But, we can't do that
    2008-05
    Honolulu
    334
    Wink Re: linking schedules with type elevation views
    well we can't expect everything to be perfect.... yet anyway..
    r
    2015-11
    Royal oak, Michigan
    1,513
    To Tag in the legend would be ideal, but if you want intelligence, you can do what I showed in the example below....elevate your doors and windows with "elevation" and you have many ways to hide the marks from plan views...and then just Tag the doors/windows with the "type" parameter.....as shown below.
    Can't wait until the factory gives more time to the legend views......tags and being able to share between projects is crucial...among being able to use the annotation part of an MEP family...
    r
    P.S. Legends are fairly new....old school revit legends is to do what I describe above and below...
    2008-05
    Brunei
    299
    r
    I believe this is one feature that needs improvement. Archicad is also struggling. You can include the door elevation with the schedule in Archicad. The downside is the elevation is not to scale, so you cannot put dimension or link a live section of a door. So Revit edges a bit there.
    Speaking of schedule, Can the header be on the side? And how to add a total for one door type (ex. Type D1 Quantity 5). The attached image is the office standard layout for our door/window schedule. Just having hard type replicating this in Revit or in Archicad. Any advise. Please.
    2005-07
    3,250
    What you're trying to do is not currently possible with schedules. Yes, you can turn the schedule 90 degrees on a sheet, but you have no control over the row spacing (it's dependant on text size). Also, there is no header property to "keep readable", so when you rotate your schedule 90 degrees anti-clockwise, if your headers are set to Vertical, they will be upside-down.
  1. Live elevation door and window schedules - not static legend views
    Last Post: 2018-08-05, 10:43 PM
  2. Copying / Linking Panel Schedules
    By wags5116 in forum Revit MEP - General
    Last Post: 2012-08-15, 01:37 PM
  3. linking totals of schedules to a tag in plan
    By Philipp Kühne in forum Revit Architecture - General
    Last Post: 2012-03-12, 08:51 PM
  4. Linking Schedules through Excel
    By Joseph TVM in forum Revit Architecture - General
    Last Post: 2012-03-03, 04:26 AM
  5. Calculating FAR - By linking Schedules
    By Mike Hardy-Brown in forum Revit Architecture - General
    Last Post: 2005-05-26, 08:49 AM
