Thread: structural framing - bad material takeoff report
    2006-11
    159
    Default structural framing - bad material takeoff report
    see atachement file for .rvt or just analize the pictures.
    When i make a roof structure i use "Metric Structural Framing - Complex and Trusses.rft" family tamplate to make all my custom family for elements. I use this family template because the elements that i create from here (like beams, rafters, braces etc)are joinable one with eachother so you`ll see all the intersection nice looking in a 3d view and even in section (not need for "edit cut profile" to use).
    All nice untill here.
    The problem i discovered is this:
    - if i join 2 of this elements the material take off display very curious things - see joined.jpg(each element has a diffrent material in order to see in section how one element "bite" from the other)
    The unjoined.jpg is the correct material takeoff. What should i do to corect this thing. I have to mention that this happen only with elements made from Metric Structural Framing - Complex and Trusses.rft template.
    2006-11
    159
    Default Re: structural framing - bad material takeoff report
    It is a bug?plz have you tryed ?
  1. 2014: Structural Framing Material Orientation Rotates when Joined
    By fyooze in forum Revit Architecture - General
    Last Post: 2013-11-14, 09:17 PM
  2. MEP2008 Structural beam material takeoff?
    By k.g.larsson in forum Style Management
    Last Post: 2009-12-10, 01:06 AM
  3. Material Takeoff does not substract Painted Material
    By joel.196524 in forum Revit Architecture - General
    Last Post: 2009-07-30, 02:15 PM
  4. Generating report of cut fil using quantity takeoff
    By darienas in forum AutoCAD Civil 3D - General
    Last Post: 2005-03-10, 02:52 PM
  5. Structural framing vs Schedule (Volume report)
    By weeleng_02 in forum Revit Architecture - General
    Last Post: 2005-02-28, 01:08 PM
