Thread: WHEN YOUR LOCAL DOESN'T WANT TO SAVE TO CENTRAL - I beat REVIT !
    2008-09
    10
    Cool WHEN YOUR LOCAL DOESN'T WANT TO SAVE TO CENTRAL - I beat REVIT !
    When you've worked for a couple of hours and then to your surprise you try to save and an evil error message says that you've run out of memory and cant save to central, but you can save your local, try this as a last resource, it worked for me:
    1 SAVE YOUR LOCAL
    2 OPEN ANOTHER INSTANCE OF REVIT
    3 OPEN YOUR LOCAL ON THE NEW INSTANCE -give it a while-
    4 IF IT OPENS, SAVE TO CENTRAL, SAVE YOUR LOCAL AGAIN -give it a while-
    5 SHUT DOWN THE NON-RESPONDING, FIRST INSTANCE OF REVIT
    6 RESTART YOUR PC
    7 REOPEN REVIT, OPEN YOUR LOCAL
    IF U R LUCKY LIKE ME, THIS SHOULD'VE FIXED THE PROBLEM
    2006-06
    Toronto, ON
    2,386
    Default Re: WHEN YOUR LOCAL DOESN'T WANT TO SAVE TO CENTRAL - I beat REVIT !
    When this happened to me, I just saved my local, restarted the computer, opened my local again and was able to save the changes made in my local file back to the central.
    Andre Carvalho
    2015-11
    Pittsbrugh
    13
    When you have done this, are ther others working off the central as well? If so, have you ran into the problem when you open another instance it comes back and tells you that your file is now outdated from the cental?
    Robert Duffy
    I could stop if I wanted to brethomp's Avatar
    2005-11
    232
    Andre's method works best for me, without the reboot.
    1. Save Local.
    2. Close Revit.
    3. Wait a minute for Revit to clean up its memory usage.
    4. Start Revit again.
    5. Open Local
    6. Save to Central
    7. Continue working.
    Definitely don't try to Save to Central when you are out of memory.
    2008-09
    10
    good point RDuffy, at the time I did this, all other users logged off the model...
  1. 2014: Revit reporting Central File is not available, no one else is in file, can't save, won't create local file
    By patricks in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2013-10-03, 10:31 PM
  2. Replies: 0
    Last Post: 2012-06-13, 08:45 PM
  3. Central File and Local Files save
    By Binu Mathew in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2010-01-16, 09:30 PM
  4. Recover backup of Revit Central or Local File
    By pbyrne in forum Revit Architecture - Tips & Tricks
    Last Post: 2006-10-21, 03:26 AM
  5. How do I save Local Client file to become Central file?
    By Richard McCarthy in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2004-03-29, 06:44 AM
