Results 1 to 9 of 9
Thread: Drawing Numbering System
    2016-01
    New Zealand
    18
    Post Drawing Numbering System
    I was hoping for a Poll on drawing numbering convention
    We are a Building Services Company & are currently tweaking our CAD Standards.
    Any ideas so we can discuss ?
    Cairo - no, not Illinois
    5,069
    Default Re: Drawing Numbering System
    When you say 'drawing numbering' are you referring to file naming and numbering, or hard-copy sheet numbering?
    Presuming the latter, the I don't think you can do better in the AEC world than the Uniform Drawing system from the Construction specification Institute, which is part of the National CAD Standards. Works well for multi-discipline jobs, and is adaptable to Civil site work. Not a good fit for roadway design, since whichever state you're in will want their DOT conventions.
    2015-12
    Near Charlotte, NC (Clover, SC)
    112
    Quote Originally Posted by jacksona View Post
    If you mean drawing sheets, I would suggest using A-100, A-101, A-102, A-201, A-301, A-401.
    All AUGI, all the time CADDmanVA's Avatar
    2006-12
    New Orleans, LA
    881
    I agree with Cadtag (obviously, just look at my sig). The NCS covers sheet naming quite well, and leaves very little for guessing. The best part is when we work with subs, and they whine about how we name sheets, we remind them its the NCS. For the most part, that stops them.
    2005-06
    in the upper right corner
    3,507
    Quote Originally Posted by cadpro78 View Post
    Yes NCS is the way to go.
    discipline-drawing type-number in series
    0= GENERAL
    1= PLANS
    2= ELEVATIONS
    3= SECTIONS
    4= LARGE SCALE VIEWS
    5= DETAILS
    6= SCHEDULES & DIAGRAMS
    7= USER DEFINED
    8= USER DEFINED
    9= 3D REPRESENTATION
    A-101 first architectural plan drawing
    A-201 first architectural exterior elevation
    S-501 first structural detail drawing
    ...and so on
    A-100 wouldn't exist in NCS as the first sheet will always end in "01"
    2015-12
    112
    Thanks for the tip...
    2006-12
    New Orleans, LA
    881
    0= GENERAL
    1= PLANS
    2= ELEVATIONS
    3= SECTIONS
    5= DETAILS
    7= USER DEFINED
    8= USER DEFINED
    ...and so on
    You actually can have 100 sheets in the NCS. If you need a general note sheet, or a cover sheet for a subset, you would probably call it a 100 sheet. The only restriction is that you cannot start the deisgn on 100 sheets.
    Don't forget too that you can double up your drawing discipline codes. When we utilize a particular geotechnical engineer to design a segmental block wall for us, I place his sheets on a LB-501 sheet. L is for Landscape since we're an LA firm, and B is for geotechnical.
    2005-06
    3,507
    Quote Originally Posted by CADDmanVA View Post
    Really? I wasn't aware of this, I stand corrected then.
    Where can I find this information? We the have NCS 3.1 book, I'd like to look that up and get more info about it.
    Yes, we sometimes utilize the level 2 designator as well, like AD-101 (architectural demolition plan) or CS-101 (civil-survey plan) and so on.
    2006-12
    New Orleans, LA
    881
    Man oh man! Time for an upgrade to NCS 4
    D is now used for process and S is for structural. I never used 3.1, but from the footnotes I've seen in 4.0, they really cleaned up and simplified things.
  1. fixing numbering/naming system for DWG files
    By tdunwoody495668 in forum CAD Management - General
    Last Post: 2014-01-22, 02:58 PM
  2. 2012: Revit Keynoting - Numbering System
    By ariellec in forum Revit Architecture - General
    Last Post: 2012-06-02, 03:52 PM
  3. drawing/tab numbering
    By vicky_lee in forum CAD Management - General
    Last Post: 2008-09-09, 09:12 PM
  4. Define Varible Numbering System
    Last Post: 2006-05-23, 03:19 AM
  5. Is their a Standardize Sheet Numbering System?
    By interceptor59 in forum Revit - In Practice
    Last Post: 2006-04-26, 03:07 PM
