I have created two standard sheet set DST files one for D-size and the other for E-size sheets. I went through setting up all aspects of creating standard subgroups and I even have some sub-groups using their own layouts for setup. For example, I created a Title Sheet subgroup and created a template for the title sheet. It is very nice using Fields to get all the information for this sheet.
All of this is fine and dandy, but here is my problem. When I go to create a new sheet set I select the drop down list and pick "New Sheet Set". When the wizard begins I select to use an existing example. The next page shows my two Standard DST files and I select the sheet size for the new set. The problem is that once it is created the sub groups no long address the correct template but rather revert to the standard template. Am I missing something here, or is this how it was designed to work. I thought it was just coping the DST file to the new location and name. Thanks for anyones help.
