Results 1 to 6 of 6
Thread: Mtext Problem
    2015-09
    72
    Default Mtext Problem
    Hello every one
    I am having trouble with my mtext, yesterday I could double click on any mtext and the mtext editor would pop up. Today nothing I have to do it manually.
    Is there a setting for this, also is there on for the Block editor?
    Thanks
    2003-12
    Pittsburgh, PA
    355
    Default Re: Mtext Problem
    Try setting Pickfirst=1
    2015-09
    72
    Pickfirst is set at 1
    2006-12
    Big "D"
    3,711
    Are you sure it's mtext and not dtext?
    The double click action is controlled by your CUI. Open that up and check to see if the action is still there under double click. You may have to recreate it.
    Why is it called common sense when it is so rare?
    RevitForum.org
    2015-09
    72
    I found out what was wrong, Setvar dblclkedit was set to off
    Thanks for your guys help pointing me in the right direction
    2006-12
    Big "D"
    3,711
    OH yeah, that too.
    RevitForum.org
  1. Mtext Problem
    By david.gray in forum AutoCAD General
    Last Post: 2010-08-19, 11:51 PM
  2. SMALL MTEXT PROBLEM
    By eldridge in forum AutoCAD General
    Last Post: 2009-04-01, 03:11 PM
  3. MText-Problem
    By h.ess172973 in forum Deutsch - AutoCAD LT / AutoSketch
    Last Post: 2008-09-08, 07:26 PM
  4. Problem with mtext doubleclick
    By office.159898 in forum AutoCAD General
    Last Post: 2008-02-12, 05:55 PM
  5. Help Mtext problem
    By Tom Phillips in forum AutoCAD Customization
    Last Post: 2008-02-06, 05:14 PM
