Thread: hiding window removes the opening for the window as well
    2008-07
    Brisbane (Ex. Swedish)
    349
    Default hiding window removes the opening for the window as well
    Hi,
    If I am in a 3D view and hide my windows the opening is still maintained in the 3D view. But when I try to hide the windows in plan view the opening for the windows is not maintained. Are there anyway I can hide the windows but still show the opening in the wall.
    I use RST2009
    Thanks
    Jonas
    All AUGI, all the time kathy71046's Avatar
    2004-07
    Perth Australia
    736
    Default Re: hiding window removes the opening for the window as well
    Most likely thing is your cut plane isn't intersecting your openings.
    You should be able to hide the windows with VG (set them to not display) rather than hiding the objects, and the openings will still show, providing your cut plane goes through them.
    Kathy Taylor
    Senior Structural Draftsperson & Proprietor
    TaylorCAD
    www.taylorcad.com.au
    I don't suffer from insanity - I enjoy it!
    Revit User Phase 3, 4, 5, 4, 3, 5, 4.....
    2008-07
    349
    Thanks Katika,
    My cutting plane was set completly wrong. Thanks
    Jonas
    100 Club Galadriel's Avatar
    2007-09
    170
    can you hide them by changing the view range?
    I don't know any other way
    2008-07
    349
    Hi,
    My problem was that my cut plane was only set at 300 above floor level and hence the reason the window opening disappeared when I were hiding the window.
    Cheers,
    Jonas
  1. 2014: Window opening marker
    By scottyermer in forum Revit Architecture - General
    Last Post: 2014-07-19, 03:50 PM
  2. Disable the F1 key from opening the Help window?
    By jnj1502 in forum AutoCAD CUI Menus
    Last Post: 2013-12-16, 08:06 PM
  3. Window Opening
    By rocks-e in forum Revit Architecture - General
    Last Post: 2009-12-16, 09:24 PM
  4. Replies: 2
    Last Post: 2007-05-21, 05:50 PM
  5. Window as Wall Opening
    By artitech in forum Revit Architecture - General
    Last Post: 2005-06-20, 03:14 PM
