Results 1 to 7 of 7
Thread: Плагины (и макросы) для Инвентора
    2007-09
    Russia, Volgograd
    90
    Default Плагины (и макросы) для Инвентора
    Постараюсь собрать в данной теме ссылки на плагины для Инвентора.
    Начну с русских плагинов:
    Редактор материалов Виктора Руленко
    Редакторы спецификаций:
    Редактор спецификаций Виктора Руленко
    Редактор спецификаций Михаила Казакова (ссылки в теме)
    Редактор спецификаций Taip Игоря Брагина
    2007-09
    Russia, Volgograd
    90
    Default Re: Плагины (и макросы) для Инвентора
    Англоязычные плагины (или отдельные программы) для Инвентора:
    3G.author - design analysis, validation, and optimization of designs created in Autodesk Inventor, Solid Edge, Pro/Engineer, Widlfire, SolidWorks, CATIA, XXen and others.
    ACAD Stahl Inventor - provides ability to create skeleton steel construction in Autodesk Inventor, by Schäfer Computer GmbH (German)
    AutoPOL Unfolder - sheet metal unfolder, handles simple models with elements like regular bends and complicated free-form models, by FCC Software AB
    CFD-CADalyzer - fluid flow mesh generation and analysis operates directly on native Inventor geometry, by ESI Group
    COPRA MetalBender TDi - sheet metal application for Inventor, with lofting, transitions, sheet metal part library, flat pattern calculation, by data M Software GmbH
    COPRA MetalBender Analyser - flat pattern calculation of sharp-edged 3D solids and sheet metal parts imported into Inventor, by data M Software GmbH
    COSMOS/DesignSTAR - offers design analysis associative with Autodesk Inventor by Structural Research Analysis Corp
    Design Manager - drawing and document management system for AutoCAD, AutoDesk Inventor and AutoCAD LT by Curve Design Solutions
    DesignDataManager – data management for SolidWorks, Pro/E, Inventor and IronCAD, by CSI
    DesignSpace - automated, knowledge-based, fundamental engineering analysis for design engineers, by ANSYS, Inc.
    Dynamic Designer - motion analysis and assembly modeling, by MSC.Software
    FX64 Plot - concurrent plotting of multiple documents from Inventor, supports and converts PDF, DWF, DWG, by FX64
    GearTrax - creates solid models of spur, helical and involute splines gears with true involute tooth profiles, by Camnetics
    GrafiCalc - pre-modeling analysis and optimization software allows evaluation of design alternatives, backsolves geometry, by GEOMATE
    Inventor/IDF PCB Modeler - allows PCB designers to create 3D models of the PCB's in Inventor, by Desktop EDA
    InventorPlot - batch plot tool for Inventor drawings
    iProperty Collection - Autodesk Inventor add-on provides a collection of small routines to customize properties, by Patrick de Stobbeleir
    MITCalc - calculations, parametric modeling, interface to Excel, for Inventor, as well as Solid Edge, SolidWorks and Pro/E
    MotionInventor - simulate and analyze the physical motion and loading of mechanical assemblies, by Solid Dynamics
    MSC.Dynamic Designer - motion analysis add-on, by MSC.Software
    Netstream Solutions - creators of iCenter, a bill of material management solution for engineering and manufacturing companies
    Quadrispace - publishing software uses CAD files to create interactive 3D documents
    SMARTEAM - IN Integration - Autodesk Inventor integration for the SMARTEAM environment for collaborative PDM
    SPI - Sheetmetal Inventor - design and unfolding of complex sheet metal parts with Autodesk Inventor
    ToleranceCalc - add-on tool to calculate acceptable tolerances by running quick simulations on a single part or combination of several parts in an assembly, by GEOMATE
    VRML Translator for Inventor -
    VRMLout translator allows to publish Inventor parts and assemblies to VRML2 3D format, AAC Solutions
    И некоторые сайты:
    The Inventor Tool Site - project file organizer, color scheme organizer, gallery, VBA/VB code, more, by Patrick de Stobbeleir
    Inventor Tools - utilities for Inventor for plotting, file name generation, more
    QWiKMcad - TopTen sited contains several utilities for Inventor
    2007-09
    Russia, Volgograd
    90
    Список продуктов совместимых с Autodesk Inventor (официальные данные Autodesk)
    2007-09
    Russia, Volgograd
    90
    Плагины от Autodesk Labs. Их особенность заключается в ограниченном сроке действия (обычно около года) и бесплатности. Позже их можно найти во встроенных функциях новых версий Инвентора или коммерческих плагинах.
    2D to 3D Tool for Inventor - Save valuable time creating 3D models of parts that were designed in 2D with this add-in utility. The 2D to 3D Tool streamlines the preparation of 2D views by automatically rotating drawing views onto orthogonal sketches.
    Advanced Simulation Technology Preview for Autodesk Inventor - include: Simulate Inventor parts and assemblies, parametric simulation of Inventor models, multi-criteria optimization, automated tools to set up simulation model.
    AliasStudio Direct Reader Add-in for Inventor - This technology preview provides the ability to communicate effectively between industrial design and engineering by directly reading a native AliasStudio wire file into Autodesk® Inventor®. The translator reads surfaces, shells, solids, and curves from the AliasStudio file. This virtually eliminates errors introduced by translations of geometry into intermediate formats such as STEP or IGES.
    Feature Recognition for Inventor - Use this application to convert neutral 3D CAD (STEP, SAT, or IGES solids) models into fully featured Autodesk® Inventor™ models.
    iMap for Inventor - Navigate your Digital Prototypes created in Inventor with iMap! iMap provides intuitive, graphical views to help Inventor users easily visualize, understand and control important relationships and constraints in Inventor assemblies – especially those that were originally created by someone else!
    Inventor Plastic Features Technology Preview - Automatic geometry creation of common technical plastic features - such as grills, rests, bosses, snaps, lips & grooves, and fillets - speeds complex plastic part design and reduces the CAD modeling expertise required for high quality designs.
    JT Translator Add-in for Inventor - With this technology preview, you can speed up and simplify projects that require opening and creating JT™ files to collaborate effectively with vendors or customers. You can easily import JT files into Autodesk® Inventor® and export JT files out of Inventor®.
    Shrinkwrap Add-in for Inventor - for create envelope parts from Inventor assemblies. Shrinkwrap Add-in for Inventor takes advantage of Inventor’s derived part workflows to create a standalone, single part solid version of a model assembly.
    Sustainable Materials Assistant for Inventor delivers: Expanded Inventor materials library with fields to add sustainability properties of commonly used materials, Sustainability Reports to analyze and document the environmental impact of selected materials, Capabilities to calculate the carbon footprint of your entire design.
    2007-09
    Russia, Volgograd
    90
    iDrive – Features include: Drive Parameters And Constraints, Drive Parameters And Constraints In SUB ASSEMBLYS & PARTS, Renumber Parameters, 'Animate' Parameters And Constraints, Revert Back To A Previously Saved Parameter Value, Suppress Constraints In SUB ASSEMBLYS
    iCoG - features include:
    1) This Add-In will show the location (x,y,z) of the CoG in both mm and in
    2) Also the mass of the model can be found on the ToTal Mass Row in Kg and lbmass. if the mass is less than 1kg or 1lb, it's converted to gram or oz for your convinience
    3) The Users have an option to place a WP at the CoG
    4) Click on the Update button to update the data if the model has been changed
    5) While the Add-In is running, the users can open or switch to a new file and hit the Refresh button to update. The active document's name should be shown in the box
    6) User Up/Down button to roll the form up and down to save some space
    7) Soon the form is moved, a new location is saved for the next time
    Users can change the Transparency for viewing
    Mini Property Equations - This addin allows you to format properties based on parameters and equations. For example it can format the description of a part as TUBING 2-1/2" x 2-1/2" x 56". Where the 2-1/2" and 56" were parameters of the part itself. Change the part size and the description updates.
    RunMeOnSave - This addin allows modules/code in VBA (default.ivb) to run on every save without much extra coding overhead
    Revision Cloud - This add-in is compatible with Inventor 9, 10 and 11, and works much like the Revision Cloud command in AutoCAD.
    YIPPEE (Yet another Inventor ProPErty Editor) Pro - is an easy-to-use add-in for Inventor 8, 9, and 10 that makes the sometimes arduous task of editing and managing the iProperties of Inventor files easy.
    FacesAsPart - for dealing with imported model faces. Sometimes, when importing model from IGES or STEP, faces may have their own color and changing part's color have no effect. With this add-in, all faces will be inspected and changed like part's renderstyle if needed.
    Associated DXF - This add-in will create a DXF/DWG file each time a sheetmetal part with a flat pattern is saved. You have different options which will determine where your DXF will be saved, and which name your DXF will get.
    COG++ - Complete COG reporting and management tool.
    - Track COG in parts, and for each Positional Rep+LoD Rep combination in assemblies.
    - Track multiple locations relative to COG.
    - Recover COG in drawing views, including overlay views.
    - Extensive UI customization, and chm based help.
    iChangeRef - The addin makes the copying of an IDW and it references a lot easier:
    1)Copy your original IDW (and reference IPT / IAM if creating new)
    2)Rename NEW IDW and NEW IPT/IAM
    3)RMB on NEW IDW choose iChangeRef
    4)Point IDW to NEW reference (Matching IPT/IAM in same directory will be selected if found)
    5)Change Reference
    AutoSaveDWF - to make an update to date DWF of the IDW, IAM or IPT each time you save.
    iTweak – for access to hidden options for Inventor.
    iReports – simple report builder for Inventor (from BOM)
    iPropWiz - is an application that replaces Inventor's standard iProperties dialogue box. It takes this functionality further by allowing the user to define which properties they will be presented. Extraneous properties can be eliminated from the dialogue leaving only those that the user wants to see. iProperties Wizard takes one more step by offering the user the chance to rename the properties by providing an alias for the property name. This allows the user to, for example, rename Web Link to something a bit more useful such as "Stock Room Location".
    iColorizor - o apply different colors to parts of a translated assembly. In an assembly file, iColorizor let you choose color styles from library's color styles and apply them alternatly to each part or occurrence of the assembly. You also can apply a selected color style to a single part or occurrence. another option let you apply a selected color to all fasteners coming from CC. In a part file, it works like FacesAsPart (previously posted) but you can select one or more faces for exclusion.
    Automatic update Drawing Resources and Styles - You have one master idw (Template) and when needed. Modify the Titleblocks,Borders and Sketched Symbols there. When you open a Inventor file the Drawing Resources and Styles from Style Library will be automatic update.
    Plot Stamps - Create and manage Plot Stamps for Inventor drawings (works inside IV and with Task Scheduler prints). Multiple plot stamps per sheet, precise positioning and formatting, client and author licenses will be available.
    2007-09
    Russia, Volgograd
    90
    Отличный список приложений для Инвентора с одноименного русского сайта тут
    2007-09
    Russia, Volgograd
    90
    Color Scheme Organizer - This Organizer makes it possible to modify the standard Color Schemes in Inventor
    iProperty Collection - This Add-in is a collection of small routines that enhances some areas of Inventor, all routines are executed automatically when the document is saved.
    To customize the properties edit the option file "iProperty.ini", it has comments inside to help understand the settings.
    Create View Rep - This Add-in makes it quick and easy to Create Quick View Representations of Single or Multiple Parts in Assemblies.
    KWiKPlaneConstrain - Allows you to quickly select planes from parts and subassemblies to add flush or mate constraints to.
    KWiKFileNew - Allows you to choose up to 10 Inventor templates to have quick access to.
    KWiKFolders - Allows you to store settings for a Inventor assembly component and apply the settings when you want.
    KWiKBatchRun - Allows you to select multiple Inventor Files, and select a Inventor Macro to run on them. It opens each Inventor file, and runs the Macro, then saves and Closes the file.
    KWiKDrive - Allows you to pick Inventor assembly constraints to drive using a slider type of control. The constraints you select are stored with the file and available any time you run KWiKDrive.
    KWiKFind - Use KWiKFind to find Parts, Subs, or sick constraints in your Inventor assembly's.
    KWiKFile - Set up your Template how you want it with Rev Block settings and sketched symbols, then use KWiKFile to start a new drawing. It start by having you pick the template, then it immediately brings up the SaveAs dialog. Once saved it closes the Template file and opens the saved file complete with the settings you had made.
    KWiKPrints32 - allow you to setup one click printing in Inventor on up to 32 buttons.
    KWiKSert - Drastically speeds up the process of adding fasteners in Autodesk Inventor or anything that gets constrained with a Insert. Select the bolt head, select a hole, and it inserts the bolt. Now you can continue by selecting holes one at a time and it will insert the bolt and constrain it as you go, or you can select a face with multiple holes and KWiKsert will only populate the holes of the same size and style.
    KWiKInsertNFix - for use with Autodesk Inventor files created using the Master Sketch method. It allows you to select multiple parts, and then it inserts them into the assembly relative to the Origin planes, and grounds them.
    KWiKShapes - allows you to define Rectangular and Round shapes with Tubing walls or not, and will add the shape fully constrained to a Autoesk Inventor sketch.
    KWiKViews - is generally set to run Automatic every time Autodesk Inventor is started. You can drag it to where ever you want on your screen, and it gives you all the standard viewing tools, along with quick standard viewing directions. Top Right ISO, Bottom Left Iso, Left, Back, etc.
  1. Replies: 7
    Last Post: 2010-04-14, 09:31 AM
  2. AutoCAD: Макросы - Управление через Internet
    By opex in forum Русский - Все про архитектурное и строительное проектирование
    Last Post: 2009-01-13, 10:03 AM
  3. Поиск текста в чертежах Инвентора
    By andrei.berezin in forum Русский - Inventor
    Last Post: 2008-10-23, 10:54 AM
