Hi guys,
You might know that the Door & Window families support the sequential numbering using the Mark Parameter. How can I make this parameter works the same way for other families, like Structural Column or Footing?
Cheers,
Vlad
Hi guys,
Cheers,
Vlad
You can download the Revit Extenstion from the subscription centre. There is a function called Elements Position that does what you want. Check it out here http://www.extensions4revit.com/n/e4r
J
Thanks a lot for your help! It works perfect.
Cheers,
Vlad
