Thread: Hidden commands you can use in Trueview 2009
    2008-07
    Boise
    63
    Default Hidden commands you can use in Trueview 2009
    I just learned today that if you copy and paste the command XREF to the command line in Trueview, you can open the Xref Manager. You can't attach new xrefs, but you can change the path of loaded xrefs.
    I would be nice of you could type it in or had a button, but that's still pretty cool.
    Does anyone else know of any secret commands or functionality for Trueview?
    Earth
    9,805
    Default Re: Hidden commands you can use in Trueview 2009
    If you use -XREF or -IMAGE, then you can actually attach xrefs and/or images.
    More here: http://cadpanacea.com/node/82
    R.K. McSwain | CAD Panacea |
  1. Silent Installs of DWG TrueView 2009
    By RobertB in forum Software
    Last Post: 2012-04-09, 09:57 PM
  2. Partially hidden commands
    By zanzibarbob7 in forum Revit Architecture - General
    Last Post: 2009-05-12, 07:40 PM
  3. Trueview 2008 with AutoCAD 2009 dwg
    By jim.vipond in forum DWG TrueView - General
    Last Post: 2008-12-22, 01:29 AM
  4. DWG TrueView 2009 is now available
    By rkmcswain in forum DWG TrueView - General
    Last Post: 2008-03-26, 06:56 PM
  5. VBA to contain hidden commands
    Last Post: 2006-08-09, 01:52 PM
