I have a multi-view block named I-FURN-CHAIR_BAR STOOL and I can’t get it to update correctly. When I created these multi-view blocks some of them were set up to be BYLAYER. I need them to be BYBLOCK.
The top view of this block is I-FURN-CHAIR-BAR STOOL_P. I use the Block Editor to open the block and I change all the linework to be BYBLOCK. I save the changes. Then to test it I change the color of the mv block to be red. Bingo. It works great.
I then use the Block Editor to open the I-FURN-CHAIR-BAR STOOL_F (front view) block and change all the linework to BYBLOCK. I save the changes and switch to the front view in model space. Then when I test it, it doesn’t change to red. It stays white. I went back into the block editor to double-check myself, and it is correct.
I tried completely deleting the front view from the multi-view block and “re-attaching” it, but that didn’t work. I tried closing out of the drawing, and out of ACA. But neither worked. If I insert the front view of the mv block directly into model space, it shows it as BYBLOCK. I also tried dragging the mv block to a palette and inserting it into another drawing. Its still a no-go.
Any ideas? It doesn’t make sense how the top works fine, but the front and side doesn’t.
