Thread: VERTICAL BRACE WORKPOINTS
    2008-07
    5
    Default VERTICAL BRACE WORKPOINTS
    When I am modeling a vertical brace in Revit Structure 2009, I cannot get the workpoint for my brace to be at the top of steel and the column face.
    Revit keeps forcing the workpoint to the center of beam and center of column.
    I know that I can modify the elevation after modeling or importing. . . Does any one know if it is possible to modify the lateral position of the workpoint as well.\
    Thanks and Regards,
    Greg
    2007-05
    25
    Default Re: VERTICAL BRACE WORKPOINTS
    Of course one option is to use the tab function and the selection point will vary. The prompt at the bottom of the screen will describe what is being attached to.
    Also, I have found that if the braces are not in the right point it is easier for me to redraw them than to try and modify an existing brace.
    I also find working with vertical braces to be particularly troublesome, and have looked for a good tutorial on them for a while and have not found one. I would appreaciate any direction toward one that anyone can give.
    2007-12
    75
    The best way I have found to setup vertical cross bracing & such is to draw it in plan view as a straight horizontal member then modify the elevation of one end to make it at an angle
  1. 2014: Error 'Face defining this non-vertical Wall is vertical'
    By dfi in forum Revit - Conceptual Design Tools
    Last Post: 2014-10-22, 12:50 PM
  2. 2014: Vertical brace-Associated level to plan view-Not Showing
    By Ampersand in forum Revit Structure - General
    Last Post: 2013-08-19, 06:27 PM
  3. Vertical Brace
    By kornackiph in forum Revit Structure - Wish List
    Last Post: 2009-07-13, 11:37 PM
  4. Vertical bracing – knee brace.
    Last Post: 2006-10-04, 02:49 PM
  5. Workpoints/planes from circular edge
    By Ron Oldenbeuving in forum Inventor Wish List
    Last Post: 2005-03-15, 09:22 PM
