Thread: Matlab with Autocad
    2004-03
    Miami, FL
    14
    Default Matlab with Autocad
    I would like to know if somebody have tried to interact Autocad from within Matlab software. I'm trying to get advantage from the capabilities of Matlab to interact with Autocad.Is there any experience out there?.Thanks a lot.
    Turlock, CA
    6,421
    Default Re: Matlab with Autocad
    Not directly with Matlab, but if it has vba, we should be able to help you connect to acad. Do you have some specific questions?
    C:> ED WORKING....
    LinkedIn
    2004-03
    Miami, FL
    14
    Well not specifically so far, but I'd like to manage the database which is created with Land Development Desktop (points); make it some changes that would increase my control over it and increase my productivity reducing possible errors and reworking. But how? I was thinking about Matlab, now you have suggested VBA, that could be a good way, I did not think about VBA, I should confess that I am an illiterate on VBA. Thanks so much.
    Turlock, CA
    6,421
    Well, if you are going to integrate Matlab with acad, you would have to use vba, provided Matlab supports vba. vba can do mathematical calculations, so you may not need Matlab. You would have to first learn vba and then acad's object model and then ldt's object model. You don't need to learn it all at once, although you'll get farther by getting a good footing with vba first. I started with a book from MS Press called Visual Basic Step-By-Step. Its a tutorial type book that will get you a good foundation in about a month. Keep an eye out at augi's atp for upcoming training.
    C:> ED WORKING....
    LinkedIn
    2004-03
    Miami, FL
    14
    Definitely you have put me on the way. I will get the tutorial book and start learning VBA; by sure it will solve many of my "problems". Thank you again, you have been very nice.
  1. 2012: Problems in autocad 2012 when opening files from autocad 2011 saved as 2000
    By debora.fernandes in forum AutoCAD General
    Last Post: 2012-06-30, 02:12 PM
  2. Replies: 15
    Last Post: 2010-09-23, 01:57 PM
  3. Replies: 6
    Last Post: 2009-06-01, 07:10 AM
  4. Replies: 2
    Last Post: 2007-03-30, 11:28 PM
  5. Replies: 21
    Last Post: 2006-12-16, 05:44 PM
