Attached is a picture of a wall with storefront ribbon windows with windows higher at the two ends and the middle portion with storefront to grade and higher in the middle.
I was wondering what the best way to do build this in Revit?
My first thought was to make a rectangular curtain wall and do all my grids and then remove the segments of grid where the actual wall would be. Then I could go in and change the panel to the wall type.
I was also thinking that I could draw 5 different curtainwalls end to end and modify base and height and overall height of each portion of windows.
Are there any other ways to do this? Is one way better than another because of other pros/cons of the method?
Shawn
