Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Placing Light Fixtures On a Reference Plane
    2008-09
    Default Placing Light Fixtures On a Reference Plane
    For those of you who have found out that a Link model of a reflective ceiling plan does not host light fixtures, you need to create a reference plane at the elevation of the face of the light fixtures. WARNING!!!.......Draw the reference plane from right to left and NOT left to right, otherwise the light fixtures will be placed upside down
    I could stop if I wanted to sschwartz85916's Avatar
    2005-04
    Oakland County, Michigan
    424
    Default Re: Placing Light Fixtures On a Reference Plane
    Quote Originally Posted by paulb.194993 View Post
    That's good to know, thanks for sharing!
    All AUGI, all the time mwiggins121466's Avatar
    2006-09
    576
    You can also create your familys as face-based to mount on the face of the ceiling.
    Margaret Wiggins
    Revit MEP 2006 and Greater
    Electrical Designer
    Detroit, Michigan
    wigginsm@yahoo.com
    Revit MEP Moderator mjdanowski's Avatar
    2007-03
    890
    Paul,
    Are you having issues with standard Revit lighting fixtures from Autodesk? Ceiling based fixtures haven't been around in a long while with Revit MEP.
    As mwiggins said, face based fixtures should be able to host on a ceiling in a ceiling plan. If you are still having trouble placing them on a ceiling make sure you:
    A) have the "Place on face" selected instead of "Place on vertical face"
    B) have the plan underlay set as "Reflected ceiling plan" in the view properties.
    C) make sure that your view depth is set correctly. This is the one that seems to get me the most, especially on projects with varying levels.
    Matthew Danowski, PE, LEED AP BD+C
    Project Electrical Engineer
    Baltimore, MD
    100 Club BigBadBIM's Avatar
    2007-07
    Madison, WI
    185
    I posted a thread about this a while ago.
    I did discover that if you draw your plane from right to left the "bottom" is down. It's related to the way Revit draws anything. Walls drawn right to left have the ext down (in plan) drawn left to right the ext is up.
    In the above post our client was having issues with the system family "ceiling basic:generic" which it turns out is a ceiling that is just basically a plane. Even face hosted objects host upside down to this. Like levels, "ceiling basic:generic" has it's "face" up.
    You can read more about it on my blog here and here.
    2007-07
    Madison, WI
    185
    Here is a quick video that tries to explain what happens with the refernce planes.
    I could stop if I wanted to Simon.Whitbread's Avatar
    2003-06
    London, UK
    352
    I think you guys are missing the issue here.
    Just as YOU want a good model from the architect, he in return should be able to have the same back.
    Using reference planes to place lights just isn't best practice and you should be looking at 'face' or 'workplane' based families.
    The example content supplied by Autodesk has gone away from the specific 'ceiling' mounted families for this very reason. Plan your families well, and they will work for most situations without the need of reference planes
    Simon Whitbread
    Revit Technical Specialist, Autodesk
    about.me/simonwhitbread
    "The distance the shotput goes, depends upon the effort that you PUT INTO IT"
    2015-08
    Menasha, WI
    74
    If you link the architects drawing into your file, the lights do NOT recognize the ceiling so you are faced with a dilema, copy the ceiling into the new drawing (duplication), redraw the ceiling (slower duplication), insert on a plane (it's an answer), or create and insert unhosted lights. The next option is to add the lights to the architects file and have them copy them into the central file.
    Any other options???
    2003-06
    London, UK
    352
    Quote Originally Posted by darin.marsden View Post
    This is one of the reasons Autodesk introduced a large range of FACE BASED families - see my examples
    Simon Whitbread
    All AUGI, all the time JoelLondenberg's Avatar
    2015-10
    508
    The lights do not recognize the ceiling as a "ceiling", but they do recognize it as a surface. When placing face hosted families don't forget to select the correct face option (see screen shots). When trying to place your light on the reflected ceiling use "Face" not "Vertical Face".
    Joel Londenberg
    BIM Box Biz - Serving all MEP Contractors
    "The best you can hope for in this life is that your delusions are benign and your compulsions have utility." - Dilbert author Scott Adams
    This is the correct date format
  1. 2013: Placing lighting fixtures on a modeled in place component....?
    By xzibited377538 in forum Revit Architecture - General
    Last Post: 2013-05-15, 03:03 PM
  2. 2012: Placing lighting fixtures with no RCP
    By Oarellano1989101485 in forum Revit MEP - General
    Last Post: 2011-10-19, 01:01 AM
  3. Pendant Light Fixtures and Light Sources
    By heiko.stugg in forum Revit MEP - Families
    Last Post: 2011-01-31, 12:25 PM
  4. Placing fixtures on ceilings
    By matt__w in forum Revit MEP - General
    Last Post: 2009-12-04, 04:27 PM
  5. light fixtures
    By johnf.77896 in forum Revit Architecture - General
    Last Post: 2008-11-14, 11:38 PM
