Thread: Civil 3D - PIPE NETWORKS
    2008-04
    41
    Question Civil 3D - PIPE NETWORKS
    Quick question, maybe not such an easy answer.
    With pipe networks, how can I assign an elevation? I choose to create a pipe network from a polyline. I drew two polylines next to each other one with 0 elevation and the other with -10 elevation. However when the pipe networks were created I did an orbit and both networks were at a zero elevation, while the original polylines remiained where they were. any Ideas?
    2003-07
    Gladstone QLD Australia
    22
    Default Re: Civil 3D - PIPE NETWORKS
    i normally select the pipe, right click, select pipe properties and assign a start and end elevation in the part properties .dialog box.
    or you can select your pipe network in the prospector window and select your pipes there and enter the elevations directly in the table that you see there.
    There could be other ways but that is normally how i set my elevations for my pipes.
    I hope this helps
    2008-04
    41
    Ok..thank you!
  1. Replies: 0
    Last Post: 2014-05-06, 09:11 PM
  2. Replies: 0
    Last Post: 2013-05-05, 03:23 AM
  3. 2013: Merging Pipe Networks
    By tim_newsome in forum AutoCAD Civil 3D - Pipes
    Last Post: 2012-11-02, 04:40 AM
  4. System Lag with pipe networks
    By zyrom in forum AutoCAD Civil 3D - Pipes
    Last Post: 2010-07-08, 02:20 AM
  5. CIVIL 3D 2006 - Pipe Networks
    By hunterhyde in forum AutoCAD Civil 3D - Pipes
    Last Post: 2006-12-04, 06:26 PM
