Thread: Placing dimensions in the 3D view
    2008-09
    4
    Unhappy Placing dimensions in the 3D view
    I am trying to place the vertical dimansions of the walls in the 3D view by using the aligned dimensions.
    However, it always places the two dimensions in the same vertical plane, which does not allow me to dimension the walls that are physically separated in the model.
    Any hint on how to fix this.
    I tried to move the dimension by moving the witness lines, but it still moves the witness line in the same vertical plane as mentined above.
    Thank you.
    2006-06
    Toronto, ON
    2,386
    Default Re: Placing dimensions in the 3D view
    You have to define your work plane first.
    Andre Carvalho
    2008-09
    4
    Smile Re: Placing dimensions in the 3D view
    Thank you Andre, it works fine now
  1. 2010: Placing dimensions on non-orthogonal radius?
    By kath.c in forum Revit MEP - Families
    Last Post: 2011-09-02, 03:14 PM
  2. Placing view on sheet
    By pdickman in forum Revit Architecture - General
    Last Post: 2007-08-24, 03:17 PM
  3. Placing Ordinate dimensions in paperspace
    By lcarignan in forum AutoCAD General
    Last Post: 2005-12-15, 09:09 PM
  4. Placing label blocks after placing the view with SSM
    By bskripac in forum AutoCAD Wish List
    Last Post: 2005-01-27, 04:01 PM
  5. Newbie needs help placing walls (dimensions)
    By max in forum Revit Architecture - General
    Last Post: 2004-05-17, 09:28 PM
