Thread: AutoCAD 2005 TIFF Image files - Image file not valid
    2015-12
    5
    Question AutoCAD 2005 TIFF Image files - Image file not valid
    We have some AutoCAD 2002 .dwg files that have TIF files attached and they open correctly, but when you open the same .dwg file in AutoCAD 2005 the tif images come up saying " Image file not valid "
    Is there a new setting in AutoCAD 2005 that is treating images differently?
    13,656
    Default Re: AutoCAD 2005 TIFF Image files - Image file not valid
    Hi
    Hopefully the following might give you one or two clues -
    Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
    ID: TS67210 - Error inserting TIFF files: Invalid File Format
    Importing OS tiles in TIF format
    Serious bitmap Problem
    Why I cannot import file tif compressed lzw?
    Have a good one, Mike
    13,656
    2015-12
    5
    By putting the 2 ddl files in the directory solved the problem.
    Thanks for the help
  1. Replies: 1
    Last Post: 2007-05-31, 12:52 PM
  2. Insert image file (TIFF) into an AutoCAD drawing file
    By snorcisa in forum AutoCAD General
    Last Post: 2007-04-15, 09:51 AM
  3. Replies: 10
    Last Post: 2007-02-07, 07:43 PM
  4. Can't Insert Tif image "Image file not Valid"
    By dguinan in forum AutoCAD General
    Last Post: 2007-01-10, 08:03 PM
  5. Replies: 0
    Last Post: 2006-10-13, 04:57 PM
