Thread: toolbar disappeared
    2008-07
    34
    Default toolbar disappeared
    Hello,
    I have my amep 2009 toolbar disappeared and when i try toolbar command
    the following message appears:
    Unable to open file c:\Documents and Settings\.....\Application Data\...MEP.cui.
    What to do.
    Thanking you in advance
    2002-09
    Madison, WI
    5,688
    Default Re: toolbar disappeared
    Sounds like something may be screwed up in your path.
    Double check to make sure that it's looking in the correct location for that cui file.
    You should be able to type "cui" at the command line, go into the CUI and load your .cui file once you find it. Unless your .cui file somehow got corrupted.
    If you know where your cui is, you could copy it to a different location and try a repair.
    But I'd wait for that one. Repairs and re-installs are about the last thing anyone would like to do.
    2000-01
    Seattle WA USA
    5,859
    If you find that the MEP.cui file is bad, you may copy the original file from the following folder (note that UserDataCache is a hidden folder):
    %ProgramFiles%\AutoCAD MEP 2009\UserDataCache\Support
    R. Robert Bell
    Design Technology Manager
    Stantec
    2008-07
    34
    Thank you Robert it works.
  1. Quick Access Toolbar Disappeared
    By christopherr in forum AutoCAD General
    Last Post: 2009-12-14, 09:32 AM
  2. Toolbar Disappeared
    By todd.mackay in forum AutoCAD General
    Last Post: 2008-04-01, 12:08 PM
  3. Is there an easy way to have a Toolbar button call up another Toolbar?
    By jonathanschade in forum AutoCAD CUI Menus
    Last Post: 2007-04-12, 04:40 PM
  4. Toolbar images not being successfully applied to custom toolbar
    By tbrown.113150 in forum AutoCAD CUI Menus
    Last Post: 2007-04-06, 05:06 PM
  5. Toolbar has disappeared and unable to get it back
    By bshank in forum AutoCAD General
    Last Post: 2004-09-07, 08:17 PM
