Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 50
Thread: Linetype Scaling
  1. #31
    0,0,0 The Origin
    8,570
    Default Re: Linetype Scaling
    Quote Originally Posted by jpaulsen View Post
    The definition of the HIDDEN linetype is different in each drawing. It appears the definition in our-file is from acadiso.lin and the definition in their-file is from acad.lin.
    If you reload the hidden linetype in both drawings from the same LIN file they will match.
    That's what I expected but, on my machine, both files open acadiso.lin.
  2. #32
    2007-08
    25
    I have reloaded the linetypes before but that did not seem to help. Plus in their original xref they have some unusal names for the hidden linetype. I had assumed it was just because they were embedded in their own xrefs before they bound the files and sent them to us. Now here is the funny thing. If I set the linetype of my line to the weirdly named hidden linetype, it shows perfectly. The appearance in the linetype manager is also different.
  3. #33
    0,0,0 The Origin
    8,570
    That's your answer then. The same linetype doesn't show differently, two similar but different linetypes (edit - with the same name) show differently. ~smiles all round~
  4. #34
    2007-08
    25
    Hold on one second. The files I uploaded, I made both with the same linetype. I purged all the others.
  5. #35
    0,0,0 The Origin
    8,570
    and, if you insert one into the other (drawing), both lines are the same.
  6. #36
    0,0,0 The Origin
    8,570
    Quote Originally Posted by shane.144689 View Post
    I think you had two different linetype definitions each with the same name.
  7. #37
    2007-08
    25
    Okay so how did the crazy named linetype name change?
  8. #38
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    Quote Originally Posted by jaberwok View Post
    That is it exactly. If you reload the linetypes in both drawings from the same LIN file and tell it to overwrite they will be the same.
  9. #39
    2002-04
    Colorado
    2,020
    Someone either loaded a linetype definition with that name or renamed the linetype in the drawing.
    Most likely the Hidden linetype definition in their-file was loaded while MEASUREMENT was set to 0 (imperial). When MEASUREMENT is set to 0 it reads the acad.lin file by default and when its set to 1 (metric) it reads the acadiso.lin file by default.
  10. #40
    0,0,0 The Origin
    8,570
    Even without reloading - insert one into the other and they become the same - either way round.
    So the first definition (the first drawing opened) wins.
  1. Replies: 5
    Last Post: 2013-06-25, 12:40 AM
  2. Linetype scaling issue
    By Cadmonkey_attacks in forum AutoCAD General
    Last Post: 2011-10-21, 08:01 PM
  3. Linetype Scaling in Viewports
    By rwright.24150 in forum AutoCAD Wish List
    Last Post: 2011-04-21, 08:54 PM
  4. Table Quirk: Scaling of Inserted Linetype Block
    By chillme1 in forum AutoCAD General
    Last Post: 2009-02-26, 11:35 AM
  5. New Linetype scaling variable
    By cadkiller in forum ACA General
    Last Post: 2007-05-18, 12:52 AM
