Thread: Fillet
    I could stop if I wanted to Kroke's Avatar
    2003-04
    Redmond, OR
    446
    Default
    How do you fillet detail lines w/ say, a 3" radius? Funny as it is, I've never done it before teehee.
    The Trim command doesn't offer anything ala acad that I can see.
    2001-12
    Irvine, CA
    7,544
    Default Re: Fillet
    Start the line command again, then one of the options is fillet, supply a radius and pick the two lines you want to fillet.
    2003-04
    Chino, CA
    4,756
    Default Re: Fillet
    its actually a part of the line or wall tool. Watch the toolbar at the top....when you switch to the wall tool, your options at the top will include a Tangent Arc and Fillet Arc. (Same toolbar where you select a Chain of walls or lines)
    Switch to Fillet Arc, pick the two lines, and either drag and select a radius by temp dim, or enter it on the fly.
    Scott D Davis
    Sr AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
    2003-04
    Redmond, OR
    446
    Default Re: Fillet
    Hmm, I see how it works now, how nifty! Thanks!
    Revit Guru gregcashen's Avatar
    2003-05
    Emeryville, CA
    1,352
    Default Re: Fillet
    Kroke, you'll have to change your sig...you've been bumped to Revit User!
  1. using fillet
    By mdsalman2003 in forum AutoLISP
    Last Post: 2010-07-06, 06:31 AM
  2. 2011: Fillet
    By Clarence Worley in forum AutoCAD General
    Last Post: 2010-05-20, 07:41 PM
  3. 3D Fillet...
    By BeKirra in forum AutoCAD 3D (2007 and above)
    Last Post: 2009-08-06, 07:02 AM
  4. fillet
    By asmaa.14-7 in forum Dot Net API
    Last Post: 2008-11-09, 12:26 PM
  5. Fillet
    By benoit1045 in forum Inventor - General
    Last Post: 2007-09-12, 09:22 PM
