i had some discussions going (both referenced in that link) after the release of 2008 regarding the failings of DB's and Annotative scaling as implemented at the time. does anyone know if any of this has been resolved or dealt with in any way - officially or otherwise. my boss is suddenly on a crusade to prove to me that there is some hack that can be used to things like section marks can be used at different scales without having to include multiple instances or layering. i searched through the forums the other day and didnt find anything, but i may not have stumbled across anything.
the basic issue is that when a length modifier is applied to a DB that is also annotative the length modifier scales with the tag, leaving the end that is stretched / moved short. if adjusted for that scale it will be too long in a larger scale.
thanks.
