Results 1 to 10 of 11
Thread: Background Mask
    5
    Question Background Mask
    Can anyone tell me how to turn on the background when you draw a dimension.... Actually, it works when I do a text box but when I draw a dimension, I can't put any background.
    150700
    3,439
    Default Re: Background Mask
    Quote Originally Posted by anton_4u
    I'm not really sure what you mean by background. Are you talking about the outline of the dimension before you place it? If yes, check your DRAGMODE variable, it should be set to On or Auto
    5
    Exclamation Re: Background Mask
    The background mask works on a mtext box but on a linear dimension it doesn't works.
    By backgroud mask I mean the way to hide lines or others objects behind your text.
    2001-05
    Austin, TX USA
    2,201
    There isn't a way of masking the background within the dimension. You will have to make a separate object like a wipeout or solid set to color 255.
    13,656
    Quote Originally Posted by gpope
    Hi
    If only that statement was true
    Check out the following links -
    Background Mask Extender
    Tips & tricks for AutoCAD 2005
    Mask Dimensions...
    Text Background Masks
    The below snippets are from AutoCAD 2005 Reviews -
    <snip>
    MTEXT and Dimension text now supports background fill/mask capability.
    </snip>
    <snip>
    Backgrounds for multiline text and dimensions. Add an opaque fill or background mask to emphasize multiline text and dimension text in a visually complex drawing.
    </snip>
    <snip>
    Mtext Improvements: You can now add a background mask on mtext (and dimensions) to hide geometry that would normally pass through it (making it unreadable). Its tied to the object, moves with it, and grows or shrinks with the annotation.
    </snip>
    Have a good one, Mike
    2001-05
    Austin, TX USA
    2,201
    Well, you got me on that one
    5
    No...sorry...it doesn't works....I know it's written in the new features found in 2005 LT but if you try to do this in the program it doesn't work....I've downloaded the background mask extender and placed the .arx in .../program files/autocad 2005 lt/ with the others *.arx, restarted autocad and tried the new commands but it still don't works.
    150700
    3,439
    I didn't think you could use arx files with LT.
    5
    That's probably why it doesn't works....well if someone can find the answer to my problem it will be very helpfull...thanks all
    Member avennem's Avatar
    6
    Does anyone know what controls the size of the background mask when you use the background fill in the Dim Style Manager?
  1. Background Mask set as default
    Last Post: 2019-02-14, 07:59 PM
  2. Background Mask
    By pants in forum AutoCAD General
    Last Post: 2014-08-06, 03:36 PM
  3. color del background mask
    By aprias in forum AutoCAD Civil 3D - General
    Last Post: 2010-01-12, 10:20 AM
  4. Dimension Background mask
    By hruiz in forum AutoCAD General
    Last Post: 2008-06-25, 12:43 PM
  5. Using BACKGROUND MASK with DWF
    By clarkrj in forum Design Review - General
    Last Post: 2008-01-22, 09:26 PM
