Thread: Can someone convert these microstation .cel files to dwg
    2003-11
    450
    Default Can someone convert these microstation .cel files to dwg
    A client emailed me files with a "CEL" extension, I am guessing they are microstation files. Can someone convert them to DWG?
    Thanks
    100 Club Ferroequine's Avatar
    145
    Default Re: Can someone convert these microstation .cel files to dwg
    Those look like MicroStation cell libraries (their version of blocks), but when I attach them to my (old) version of MicroStation, they error out.
    2007-07
    89
    Corporate network security stops me downloading your zip file so flying blind but...
    Try changing the file extension of the CEL files to DGN and then reference / import if you have 2008/2009 AutoCAD.
    After this get the client to save the cell libraries as DWG files if they are using Microstation V8 onwards.
    If they are still using the V7 DGN file format they will need to do a bit more work to convert the files.
    2003-11
    450
    Lunkwill,
    Thanks, that worked!!! I changed the extension to dgn.
  1. 2014: Convert to microstation v7
    By gregfarz78 in forum AutoCAD General
    Last Post: 2014-10-07, 12:02 PM
  2. convert from microstation pen settings
    By robert.severance292637 in forum CAD Management - General
    Last Post: 2011-12-12, 05:38 PM
  3. Microstation DGN files
    By WScottAllenPE in forum AutoCAD Civil 3D - General
    Last Post: 2010-08-20, 04:39 PM
  4. Replies: 9
    Last Post: 2007-05-30, 03:32 AM
