Results 1 to 9 of 9
Thread: Set all colours to 'By Layer'
    2008-06
    Adelaide, South Australia
    279
    Default Set all colours to 'By Layer'
    Before I start I should say that 'colours' DOES have a 'u' in it... I'm Australian...
    I'm looking for a script that I can run to set everything (including stuff in blocks) to 'by layer'.
    I'd rather not go through every drawing, explode or edit all the blocks and set the colours to 'by layer'.
    I heard that a script like this exists but have no idea where to find it. Anyone know?
    Rather not write the thing myself.
    2008-06
    279
    Default Re: Set all colours to 'By Layer'
    Nevermind, did it myself.
    ;;;'By Layer' Reset - By Randy Rossi 2008
    ;;;Type 'bylayer' to start.
    ;;;Will not change XREFS, will change blocks as well as nested blocks.
    (defun c:bylayer() ;;;comment out this line to enable script to autorun when in startup suite
    	(command "setbylayer" "all" "" "yes" "yes")
    	(SETQ tm1 (GETVAR "TILEMODE"))
    	(IF (= Tm1 1)
    		(PROGN
    			(SETVAR "TILEMODE" 0)
    			(SETVAR "TILEMODE" 1)
    	(IF (= tm1 0)
    		(PROGN
    Yes, I know.... simple, didn't occur to me to use "setbylayer". Completely forgot about it.
    2005-06
    in the upper right corner
    3,288
    Glad you could figure it out and share it with us.
    Also look at this thread which discusses this very issue, solved with a lisp routine someone posted.
    Ted
    ____________________________________________________________________ ________________
    Windows 10
    AutoCAD 2018 - REVIT 2019 - Inventor Professional 2017 (when I can)
    2000-01
    Seattle WA USA
    5,859
    Quote Originally Posted by schrodingerscat View Post
    You are aware of the SetByLayer command in recent versions of AutoCAD, aren't you?
    R. Robert Bell
    Design Technology Manager
    Stantec
    2015-11
    Jo'burg SA
    4,512
    Quote Originally Posted by RobertB View Post
    Brilliant ... another one for my little black book!
    2007-03
    57
    Try it. Load and type in command line ColorX
    (defun C:COLORX ( / doc col)
      (vl-load-com)
      (setq doc (vla-get-activedocument (vlax-get-acad-object)))
      (vla-startundomark doc)
      (mip:layer-status-save)
      (if (setq col (acad_colordlg 256 t))
      (ChangeAllObjectsColor doc  col);_ col — color number
      (mip:layer-status-restore)
      (vla-endundomark doc)
      (princ)
    (defun ChangeAllObjectsColor (Doc Color / tempObjType ColCnt RowCnt)
    (vlax-for Blk (vla-get-Blocks Doc)
     (if (= (vla-get-IsXref Blk) :vlax-false)
      (vlax-for Obj Blk
        (if (vlax-property-available-p Obj 'Color)
          (vla-put-Color Obj Color)
    (defun mip:layer-status-restore ()
        (foreach item *MIP_LAYER_LST*
          (if (not (vlax-erased-p (car item)))
            (vl-catch-all-apply
              '(lambda ()
                 (vla-put-lock (car item) (cdr (assoc "lock" (cdr item))))
                 (vla-put-freeze (car item) (cdr (assoc "freeze" (cdr item))))
                 ) ;_ end of lambda
              ) ;_ end of vl-catch-all-apply
            ) ;_ end of if
          ) ;_ end of foreach
        (setq *MIP_LAYER_LST* nil)
        ) ;_ end of defun
      (defun mip:layer-status-save ()
        (vlax-for item (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
          (setq *MIP_LAYER_LST* (cons (list item
                                      (cons "freeze" (vla-get-freeze item))
                                      (cons "lock" (vla-get-lock item))
                                      ) ;_ end of cons
                                *MIP_LAYER_LST*
                                ) ;_ end of cons
                ) ;_ end of setq
          (vla-put-lock item :vlax-false)
          (if (= (vla-get-freeze item) :vlax-true)
          (vl-catch-all-apply '(lambda () (vla-put-freeze item :vlax-false))))
          ) ;_ end of vlax-for
        ) ;_ end of defun
    2005-06
    3,288
    Which versions of Acad?
    I'm in 2006 and this command doesn't work.
    (wish it did..... )
    Ted
    Windows 10
    2000-01
    Seattle WA USA
    5,859
    (wish it did..... )
    2008 and above.
    R. Robert Bell
    Stantec
    All AUGI, all the time Norton_cad's Avatar
    2016-02
    Sydney, Australia
    512
    (wish it did..... )
    I have a couple of Lisp routines that will sort out any blocks & nested entities, and will work fine with 2006.
    Ohm's Law - Electricity follows the path of least resistance.
    Regards,
    Mark Norton,
  1. Changing layer colours in viewports using 2009
    By camilla.mott in forum AutoCAD General
    Last Post: 2009-06-30, 02:22 PM
  2. Colours (You cant take Autocad out of the boy)
    By blairmack in forum Revit Architecture - General
    Last Post: 2008-05-31, 02:21 AM
  3. Light Colours
    By Jit in forum Revit - Rendering
    Last Post: 2005-03-08, 09:33 PM
