Results 1 to 10 of 13
Thread: How to Find a Layer if It Exists?
    2006-04
    (getpoint "Anywhere on the Enter Key =>")
    1,160
    Default How to Find a Layer if It Exists?
    Hello ALL,
    I had a problem with my routine.
    What I want is:
    (1) Find a layer "Landscape" if it exists;
    (2) If the layer exist, change it's color to "green" bylayer.
    (3) If it doesn't exist, create it then set it to current.
    I can do the steps (2) & (3) except step (1)
    Any helps would be appreciated.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,917
    Default Re: How to Find a Layer if It Exists?
    Try
    (tblsearch "LAYER" "Landscape")
    2006-04
    1,160
    Try
    Thanks, tblsearch is the one, but how could it tell if it found the layer?
    I mean, what is the statement exactly?
    Will it be:
    (if (eq (tblsearch "LAYER" "Landscape"))
    (command "-layer" "set" "Landscape" "color" "3" "" ""))
    I am sure that the eq function is wrong.
    But what is the replacement for it?
    100 Club CADmium's Avatar
    2004-08
    Eberswalde, Germany, Europe
    128
    (if (tblsearch "LAYER" "Landscape")
    (command "_-layer" "_set" "Landscape" "_color" "3" "" "")
    (command "_-layer" "_make" "Landscape" "_color" "3" "" "")
    Earth
    9,803
    Quote Originally Posted by BoKirra View Post
    ...but how could it tell if it found the layer?
    The (tblsearch) function will return nil if the table entry is not found.
    So you just test it for a non-nil value.
    http://www.hyperpics.com/customizati...nce.asp?id=200
    R.K. McSwain | CAD Panacea |
    2006-04
    1,160
    with thanks to all.
    2006-04
    1,160
    Try
    From the HELP, I found the following description for the tblsearch function:
    (tblsearch table-name symbol [setnext])
    With your sample, the table-name is LAYER.
    And another one I know is STYLE.
    How to get the complete list of table-name?
    Thanks again.
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    . . . How to get the complete list of table-name?
    From the HELP tblnext, valid table-name values are "LAYER", "LTYPE", "VIEW", "STYLE", "BLOCK", "UCS", "APPID", "DIMSTYLE", and "VPORT".
    : ) Happy Computing !
    kennet
    Certifiable AUGI Addict
    2015-11
    Jo'burg SA
    4,512
    And to see exactly what's returned if the layer is found with tblsearch, check the DXF / TABLES Section in Developer Help.
    2006-04
    1,160
    Quote Originally Posted by kennet.sjoberg View Post
    kennet
    Thank you & also thanks to irneb.
  1. Find text, change layer
    By demetrius.adams707933 in forum AutoLISP
    Last Post: 2015-09-01, 11:24 PM
  2. 2015: Cannot see or find veiwport layer!
    By Cosmic Traveller in forum AutoCAD General
    Last Post: 2015-07-23, 04:41 AM
  3. Layer - Find References
    Last Post: 2013-02-19, 03:38 PM
  4. Can't find created layer
    By Jamord00 in forum ACA General
    Last Post: 2008-01-10, 10:11 PM
  5. Replies: 19
    Last Post: 2006-02-12, 11:06 PM
