Well I have had partial success in using multiple line text attribute with background masking turned on. Unfortunately the background mask seams to be a little bigger then the attribute I want it to mask. It is as though there is one more character behind the last one. This is interfering with line work I don't want masked. Have you ever experienced this before?
David Raynor
P.S. attached is an example of the problem. Notice the circle is broken in the bottom right quadrant because of the background mask. I have played with the offset settings, but the extra space at the end of it is the problem, not just the offset.
