Results 1 to 6 of 6
Thread: Revit Architecture Wall Insets
    2015-11
    9
    Default Revit Architecture Wall Insets
    Does anyone know if you can create an inset in a portion of a wall? I have a wall that is supposed to be set back 8" at every window. I can't figure it out.
    AUGI Addict Andre Carvalho's Avatar
    2006-06
    Toronto, ON
    2,386
    Default Re: Revit Architecture Wall Insets
    You could either create it as a void cutting the wall (part of the window family) or just a wall based void. In the family just create the void and make sure it cuts the wall. You can add parameters to it to control the depth. If doing it in the window family, you should delete the actual window opening and replace of with a void because you can't have an opening and a void cutting the wall at the same time.
    Andre Carvalho
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    You can embed walls, so I just make multiple wall types, then draw them overtop of each other, then use the cut geometry tool to embed the one wall into the other.
    Scott D. Brown, AIA
    BECK
    2008-04
    Boston, MA
    50
    Quote Originally Posted by Andre Carvalho View Post
    Andre Carvalho
    Andre,
    In using this method, does the wall know to wrap materials around behind the inset? That way the finish material is still visible, rather than being cut and showing the structure beyond.
    2006-06
    Toronto, ON
    2,386
    Quote Originally Posted by jkady View Post
    Andre,
    If you go to your wall's properties > Edit/New > and change Wrapping at Inserts to be Exterior or both (depending on what you want), the finish will wrap exactly where the void is cutting the wall (in plan). You can then use the paint bucket to paint the material in 3D.
    But depending on the depth of the inset, it may be hard to control the finishes and then using Scott Browns idea of building another wall and embedd them would be better.
    Andre Carvalho
    2004-06
    144
    on controling material returns:
    In the window family, you can add up to two Reference Planes (one for interior and one for exterior), select them and check "wall closure" in properties - this will allow you to control how deep the materials return into the wall. You can even add dimensions and control this via parameters.
  1. AB224-7C: Not Your Everyday Curtain Wall System in Autodesk® Revit® Architecture
    By Autodesk University in forum Architecture and Building Design
    Last Post: 2015-08-07, 02:12 PM
  2. 2013: Door Family - Reporting Parameter - Wall Thickness; Revit Architecture 2013
    By bmaxwell143848 in forum Revit Architecture - Families
    Last Post: 2015-01-21, 09:21 AM
  3. 2013: Revit Architecture - Wall Tags and Wall Legend (sketch of wall)
    By ROBP-RDS in forum Revit Architecture - General
    Last Post: 2013-07-02, 05:52 PM
  4. Replies: 12
    Last Post: 2012-01-09, 04:43 AM
  5. Can't find override for wall surface patterns - Revit Architecture 2008
    By craig.124331 in forum Revit Architecture - General
    Last Post: 2007-04-24, 07:07 PM
