Page 3 of 10 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 96
Thread: State Seals
  1. #21
    2000-01
    Seattle WA USA
    5,859
    Default Re: State Seals
    Quote Originally Posted by dreaded.knight View Post
    Mississippi does not allow electronically produced seals at this time. You can find that info on their site. http://www.pepls.state.ms.us/RulesWebSite.pdf
    I don't see anything prohibiting the production of a drawing with a digitally produced seal.
    R. Robert Bell
    Design Technology Manager
    Stantec
  2. #22
    Super Moderator rkmcswain's Avatar
    Earth
    9,666
    Quote Originally Posted by RobertB View Post
    I was just about to post the same thing.... Too bad the graphic in the PDF is so poor...
    R.K. McSwain | CAD Panacea |
  3. #23
    2008-10
    46
    Nothing specifically says you can't, but it does say
    "4. Rubber stamps, which are identical to the approved seals, in size, design and content may be used by the licensee at his option." Which does not include an electronically produced seal. A follow up call to the board confirmed this. But, if you wish to use a CAD generated seal for Mississippi, you do so at your own risk.
  4. #24
    2000-01
    Seattle WA USA
    5,859
    Actually, that item 4 is rather funny. Just how is an engineer supposed to get the seal on said documents if they elect to not get a rubber stamp?
    It sounds like Mississippi is very last millennium. I bet they still require a "wet" signature and/or date. We finally got Washington state to dispense with that archaic requirement.
    R. Robert Bell
    Stantec
  5. #25
    Earth
    9,666
    Is the other option an embossing seal...?
  6. #26
    2000-01
    Seattle WA USA
    5,859
    Since it is not explicitly defined, apparently no.
    R. Robert Bell
    Stantec
  7. #27
    2008-10
    46
    Actually, I disagree. If you get technical, the embossing is actually the only true form of "seal". Everything else is a reproduction. New Jersey specifically states that it only allows the "impression" type of seal.
  8. #28
    2008-10
    46
    Most states, I have found, require a wet signature. Even if they allow for a CAD generated graphic of the seal.
  9. #29
    Earth
    9,666
    That is true in Texas.
  10. #30
    2007-06
    271
    In Hawaii, it depends on who you're submitting to. Some agencies take electronic stamp and sig, others just electronic stamp. And one requires you to wet sign with BLUE ink, to make sure it is wet signed.
  1. Managing seals
    By AaronC in forum Revit MEP - General
    Last Post: 2012-07-19, 02:46 PM
  2. Electronic Seals on Drawings
    By joshuawulf in forum CAD Management - General
    Last Post: 2009-04-14, 01:22 PM
  3. Official Cadized State Seals??
    By cadpro78 in forum CAD Standards
    Last Post: 2008-12-16, 03:23 PM
  4. Engineering Seals
    By csutton2181 in forum Revit MEP - General
    Last Post: 2008-11-21, 10:46 PM
  5. Visibility of seals
    By bskripac in forum Revit Architecture - General
    Last Post: 2005-12-22, 06:45 PM
