Thread: XREF Palette to Operate the Same For All References
    ACAD Wish List Administration
    2005-06
    1,920
    Default XREF Palette to Operate the Same For All References
    Summary: Any reference attached to a drawing, be it DWG, DWG, DGN, image, should be attached the same as other references.
    Description: External reference palette should always operate the same way for all references
    How Used: When a user attached a DWG Xref, image, DWF or DGN he would just select attach reference and not have to select different items from the menu also, the Datalink command would be accessed in the same way.
    So all types of references would be attached to the drawing in the same way.
    This would reduce confusion (especially the way the Datalink command works and is displayed in the reference palette)
    Feature Affinity: XREF
    Submitted By: Kevin Bell on July 23, 2008
    Earth
    9,803
    Default Re: XREF Palette to Operate the Same For All References
    They have different options because they are different file types and require such. What is confusing about it?
    R.K. McSwain | CAD Panacea |
  1. 2014: XREF Palette has desapeared
    By dseay595145 in forum AutoCAD General
    Last Post: 2014-03-25, 02:49 PM
  2. Display xref names in "References - Unsolved Reference File" dialogbox
    Last Post: 2013-02-17, 01:40 PM
  3. View Range Should Operate Like Section Box
    By Limbatus in forum Revit Architecture - General
    Last Post: 2011-04-10, 04:28 PM
  4. Scheduling block references through an xref?
    By PEWAUKEEJOHN in forum ACA General
    Last Post: 2006-03-16, 09:22 PM
  5. Tool Palette & Xref
    By costas.vassiliou in forum AutoCAD General
    Last Post: 2005-08-04, 10:46 AM
