Results 1 to 10 of 10
Thread: Barn Siding - Board & Batten
    All AUGI, all the time gwnelson's Avatar
    2003-04
    Westchester County, NY, USA
    612
    Default Barn Siding - Board & Batten
    We're disappointed with the rendering results using mapping for the siding. No shadows or highlights. I'm almost ready to model an array around a smallish house, but am a little scared off by the prospect of having to cut through everything for windows & doors, and then trimming at the roof line. And so on.
    I'm soliciting ideas, offering Class A Wachovia stock in return. Or a bag of jelly beans. Or my sincerest gratitude. Whatever.
    Thanks.
    2003-11
    442
    2
    Default Re: Barn Siding - Board & Batten
    I've used the curtain wall tool for board and batten siding on a few projects and it works pretty well. Just set the panel to 'empty', and define the size and spacing of the vertical mullion as your batten.
    2006-09
    The Kingdom of Denmark
    560
    Wink Re: Barn Siding - Board & Batten
    You could also create a profile, that defines what to cut of the wall, and use: Modelling>Wall Reveal - Or if it´s horizontal siding, you can add a bunch of reveals at the wall properties menu.
    2004-11
    Wisconsin
    302
    Quote Originally Posted by muttlieb View Post
    muttlieb, So do you have (2) separate walls then?
    John Fleming
    2003-11
    442
    Yes, a basic wall representing the framing and finish except for battens, and a curtain wall that only includes the battens.
    2004-11
    Wisconsin
    302
    ok, that is what I thought.
    thanks
    John Fleming
    2007-02
    Alexandra, New Zealand
    237
    How do you get the windows and doors to cut the battens then???? Cheers
    Phillip
    100 Club Graham Briggs's Avatar
    2006-02
    Arcadia, CA
    117
    Quote Originally Posted by Phillip_Miller View Post
    Phillip
    Use "Join Geometry" on the adjacent walls. Windows, doors, etc. that are hosted by the main wall will also cut the battens.
    2003-11
    442
    Quote Originally Posted by Graham Briggs View Post
    Actually, you have to edit the profile of the curtain wall and cut around the openings. Sorry I left that part out! Yeah, it can be tedious, and I would only use this method if you absolutely need it for a rendering.
    Member kurk's Avatar
    2005-04
    New Zealand
    48
    I have simply been using vertical wall sweeps from a batten profile which has allowed me to quickly put window surround battens in place also. Admittedly this has been for a couple of small poolhouse pavilions and a farm shed so they didnt take too mcuh time to array and place. The battens automatically stop and start either side of the window as if cut also.
    I like the curtain wall and join geometry idea and I can maybe still place wall sweeps around the windows - if it wasnt worth building them into the window families of course.
  1. Does anyone have a batten board siding pat file?
    By Kroke in forum Revit Architecture - General
    Last Post: 2023-09-11, 04:55 PM
  2. lap board siding
    By frank.richarz in forum Its all in the Details
    Last Post: 2010-10-07, 01:41 PM
  3. Board and Batten Wall Style
    By Bill.Jensen in forum ACA Wish List
    Last Post: 2006-07-15, 07:04 PM
  4. Need Board and Batten Hatch and Accurender Material!
    By rgecy in forum Revit Architecture - General
    Last Post: 2005-04-26, 06:22 AM
  5. Anyone have a good Board and Batt siding texture?
    By hdjohnson in forum Revit - Rendering
    Last Post: 2004-02-10, 06:49 PM
