Thread: Migration from AutoCAD 2006 to 2009
    2008-10
    2
    Default Migration from AutoCAD 2006 to 2009
    I am researching known problems, pitfalls and bugs with migrating Autocad 2006 to 2009 trying to avoid any work flow issues during and after the upgrade. I am also running 2008 CadWorx and will upgrade to 2009 at the same time. Any info is appreciated!
    Thanks.
    2008-09
    12
    Default Re: Migration from AutoCAD 2006 to 2009
    Hi don.rogers. Not sure what you're asking. Are you looking for anyone's problems, bugs, etc. reports during migration?
    2015-12
    2,095
    Start from scratch - profiles, CUI files, pgp files, everything except your own LISP/VBA support routines (and go over those with a fine-tooth comb). There are enough changes between the two versions that it isn't worth trying a "migration". Check all of your third-party programs and object enablers, as all of those will also require upgrading to 2009-compatible versions as well. CADWorx is much more tolerant of version changes than many other programs. Its also a good opportunity to weed out any systemic problems.
    Don't forget to get the available service packs and hotfixes as well.
    2008-10
    2
    Quote Originally Posted by srajeshh12 View Post
    Yes I am looking for any and all problems before we deploy 2009.
  1. Migration from AutoCAD 2008 to 2009
    By U.Rackharrow in forum AutoCAD General
    Last Post: 2009-02-26, 02:21 PM
  2. ADT 2006 New plotter pc3 migration?
    By mcervantes in forum ACA General
    Last Post: 2008-07-18, 01:45 PM
  3. Label style Migration: 2006 to 2008?
    By rdomke69 in forum AutoCAD Civil 3D - General
    Last Post: 2007-09-18, 11:02 AM
  4. Menu Migration Experiences 2004-5 v. 2006-7
    By Steve Johnson in forum AutoCAD General
    Last Post: 2006-06-29, 02:59 AM
  5. 2006 to 2007 Dynamic Block Migration
    By jas in forum Dynamic Blocks - Technical
    Last Post: 2006-04-20, 03:51 PM
