Results 1 to 10 of 12
Thread: Dimension arrows not showing
    AUGI Addict Railrose's Avatar
    Abilene, TX
    1,181
    Default Dimension arrows not showing
    My supervisor & I are both having trouble getting filled arrows to show up on dimensions. There is a blank space where they should be.
    All non-filled arrow types show perfectly.
    Any ideas?
    Give people a job worth doing, the tools to do it, recognition of a job well done & get out of the way.
    2006-12
    Big "D"
    3,711
    Default Re: Dimension arrows not showing
    Is fillmode set to 1?
    Abilene, TX
    1,181
    it is set to 1.
    2006-12
    Big "D"
    3,711
    Can you post the dim in question?
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    Do you have Raster Design installed?
    See Solid Filled Object Hotfix.
    Active Member davidmatyas's Avatar
    2005-01
    72
    SHADEMODE set to anything but 2D wireframe will produce unfilled arrowheads as well.
    2005-06
    in the upper right corner
    3,515
    Quote Originally Posted by dzatto View Post
    What kind of arrow is assigned in the dimension style (or the dimensions in question)?
    Is it a user arrow?
    What does the "dimblk" look like????
    (is it possible it got redefined to something different than expected)
    Abilene, TX
    1,181
    Quote Originally Posted by jpaulsen View Post
    That fixed it. Thank you.
    Abilene, TX
    1,181
    Quote Originally Posted by davidmatyas View Post
    I typed shademode, & ACAD crashed.
    Abilene, TX
    1,181
    Is it a user arrow?
    It's OOTB dimension settings.
  1. 2013: Pls Help!!! Pls...Link Dimension not showing up..
    By limruian in forum Revit Architecture - General
    Last Post: 2014-03-19, 04:10 AM
  2. Inverting Dimension Arrows
    By spyrc in forum AutoCAD LT - General
    Last Post: 2010-03-16, 04:47 PM
  3. Dimension Arrows show a gap near selected Lines
    By Animesh Kundu in forum AutoCAD General
    Last Post: 2006-04-11, 07:04 AM
  4. Control Dimension Arrows via Properties Palette
    By mhudson in forum AutoCAD General
    Last Post: 2006-01-16, 02:05 PM
  5. Dimension lines and arrows disappear while dragging
    By bkrebbs in forum AutoCAD General
    Last Post: 2006-01-04, 11:24 PM
