Thread: tahking a 3d model from revit into sketchup
    2008-10
    4
    Default tahking a 3d model from revit into sketchup
    having problems exporting 3d model from revit into sketchup.i tried exporting as a dwg,but it just produces lines on a plain.I exported with dxf into autodesk viz.it came out as a 3d model,but all the materials and textures are gone,and it's fuzzy.anyone have any ideas.really need the help
    Thanks
    2008-02
    Los Angeles, CA
    248
    Default Re: tahking a 3d model from revit into sketchup
    You have to be in a 3D view in Revit then export to dwg. but the materials will not transfer to SketchUp.
    If you want to go Revit to Google Earth, you can use the Revit Google Earth Extension which will not only export your model to a Sketchup format, but it will place it in the correct site and orientation in Google Earth.
    http://labs.autodesk.com/utilities/g...xtension_beta/
    Cheers..
    2003-05
    East Walpole, MA
    893
    That links to an autodesk page that doesn't list a Revit to Google Earth Extension.?? Was Revit dropped, anyone know? I haven't been able to find the Revit to Google Earth Extension
    2006-05
    836
    It should be a available from the membership subscription site. You need a login and password. Otherwise you could try the Avatech Revit Add-on solution.
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Cool Re: tahking a 3d model from revit into sketchup
    The Google Earth Plug-in for Revit is called Globe Link, and is available on the
    Subscription site.
    cheers........
  1. Redering Sketchup Model in NW 2010
    By SaltyNole in forum NavisWorks - General
    Last Post: 2010-02-19, 12:08 AM
  2. inserted sketchup model not being cut by section
    By sami in forum Revit Architecture - General
    Last Post: 2010-01-22, 11:50 PM
  3. Revit and a heavy weight SketchUp model?
    By ron.sanpedro in forum Revit Architecture - General
    Last Post: 2007-07-01, 03:42 AM
  4. Export of 3D Revit model to Sketchup possible?
    By abink in forum Revit Architecture - General
    Last Post: 2006-12-05, 11:33 PM
  5. Revit Model imported into SketchUP
    By Kroke in forum Revit - Gallery
    Last Post: 2004-03-01, 05:23 AM
