Thread: compiler from C++ .net to C++ ver 7.0
    2001-11
    6
    Question compiler from C++ .net to C++ ver 7.0
    I've recently installed the Visual studio .net 2003. I want to create a few ARX programs and have the need to make them into the format for Autocad 2005. I downloaded the new SDK from Autdesk and I'm ready to install and use.
    What help is available?
    Where do I get a patch that will let me compile the ARX programs?
    2001-11
    6
    Default Re: compiler from C++ .net to C++ ver 7.0
    To any of you that are interested, the Microsoft support center can give you a downgrade version to the visual C++ .net 2002 if you want to go through the pain of it. I spent quite a few calls back an forth, and finally got the mission accomplished .
    You will need to call Microsoft Supplemental and Replacement Parts Center at (800) 360-756, this is what I got from the tech support. You also have to go on line and fill out an approval form from them and fax it with the conformaton number to them.
    now I am waiting for the software to arrive.
  1. dll compiler
    By awarren in forum AutoCAD Customization
    Last Post: 2008-09-19, 07:08 PM
  2. Compiler options
    By cadhelp Van in forum Dot Net API
    Last Post: 2007-10-16, 04:31 PM
  3. SHP to SHX compiler?
    By jgardner.79905 in forum ACA General
    Last Post: 2006-10-18, 04:57 PM
  4. Free compiler to program in C++?
    By clovis in forum ARX
    Last Post: 2006-08-15, 05:12 AM
  5. video compiler
    By sfaust in forum Revit - Rendering
    Last Post: 2005-11-03, 05:33 PM
