Thread: Can't Notch or Trim
    2008-10
    Default Can't Notch or Trim
    I can't select curved frame to Notch frame 1 to frame 2
    or Trim frame 1 to frame 2.
    Because it is curved or...?
    Please help
    Williamsport, PA
    641
    Default Re: Can't Notch or Trim
    Zip and attach your files here. I think you will need to edit the part within the context of the assembly using Copy Face from the trimming part as a surface and then Sculpt with the cut option.
  1. Trim, trim objects/selection issue 2010
    By stevej.57608 in forum CAD Management - General
    Last Post: 2009-07-08, 04:09 PM
  2. Notch in Wall
    By kwong in forum Revit Architecture - General
    Last Post: 2005-07-22, 01:22 AM
  3. Notch detail
    By robert.1.hall72202 in forum AutoLISP
    Last Post: 2005-06-10, 07:41 PM
  4. Create This Notch
    By robert.1.hall72202 in forum AutoCAD General
    Last Post: 2005-03-02, 09:53 PM
  5. Rafter notch?
    By gjburkett in forum Revit Architecture - General
    Last Post: 2005-01-07, 10:37 PM
