Results 1 to 6 of 6
Thread: Create All Layers in Current Layer Key Style
    2003-03
    Philadelphia, PA
    2,390
    Default Create All Layers in Current Layer Key Style
    The attached ZIP file contains an AutoLISP file that defines a command called LKL that will generate all of the layers defined in the current Layer Key Style. It should work in ADT 3.3 through ACA 2009, although I have only tested this directly in 2004. (Most of the code deals with assuring the proper ARX file is loaded for the version of ADT/ACA being run - that was copied from another routine that has been tested in all of those versions.)
    Note that if a layer already exists in the drawing in which the command is run, the layer will be left "as is" (just like it is when an AEC command or tool references a Layer Key)>
    Also note that if Layer Key Overrides are enabled and any are set, the generated layer names will reflect the override settings.
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Default Re: Create All Layers in Current Layer Key Style
    You must spread some Reputation around before giving it to dkoch again.
    Genius. Pure Genius.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2005-07
    2,356
    That's awsome David, need to do some spreading as well, have a instead.
    2003-03
    Philadelphia, PA
    2,390
    Here is an updated version, that supports ADT 3.3 through ACA 2012.
    2006-12
    12
    EXCELLENT!
    2015-12
    49
    Thanks for the update!
  1. Create segment labels on current layer
    Last Post: 2013-11-05, 05:41 PM
  2. Use current layer as an option for label layers at creation
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2013-10-11, 06:23 PM
  3. Replies: 1
    Last Post: 2006-07-25, 03:33 PM
  4. Replies: 7
    Last Post: 2006-03-15, 08:30 AM
  5. Replies: 19
    Last Post: 2006-02-12, 11:06 PM
